a couple of questions about brakes!
Re: a couple of questions about brakes!
#61 Post by tony g »
I still think wherever the caliper is the grabbing force is the same (given the same radius from the centre)
xvivalve wrote:
soe8m wrote:Having drum brakes on your wheelbarrow will have the same effect.
Lever, fulcrum and load; the point at which the load is applied will make a huge difference, particularly so if it moves from one side of the fulcrum to the other despite the actual distance being small.
(but yes, I take your point that the parts attached will want to rotate around the wheel in all cases)
#62 Post by soe8m »
tony g wrote:But the rack is at the rear and so is the caliper on a Dolomite... Did they do a different version?
soe8m wrote:Purely practical. Most rwd cars have the trackrods at the front and fwd cars at the rear. You want as less heat in the near of balljoints so triumph did a good job on the dolomite.
Some competition car's and f1 have the calipers at the bottom for lower centre of gravity. When a wheel is braked the parts attached, a car or wheel barrow want to turn around it. Having drum brakes on your wheelbarrow will have the same effect.
The best would be at the front at a dolomite.
#63 Post by tony g »
But you said they did a good job
#64 Post by Toledo Man »
The Dolomite was derived from the FWD cars and they carried over the rack and the front brakes.
#65 Post by soe8m »
tony g wrote:But you said they did a good job
I'm very sorry. I did forget the dots behind job.....
Jeroen.
#66 Post by soe8m »
Toledo Man wrote:The Dolomite was derived from the FWD cars and they carried over the rack and the front brakes.
At the fwds already they started doing it wrong.
