I have the hydraulics drained at the moment as I have fitted the Trackerjack front conversion. I'll do a separate post on that, but a million thanks to Jon for his assistance.
So anyway I thought it a good time to fit the rear braided hose. The replacement hose has an adaptor supplied with it which threads into a swivel union on the hose (see the photos). I removed the old flexi OK, but when I went to fit the new hose the thread wouldn't start in the load sensing valve. I compared the threads of the old and new, the Goodridge hose is definitely about 0.5mm larger diameter.
I'm pretty sure the thread in the LSV is 3/8"UNF, but the adaptor supplied has the cuts in the nut to indicate it's a metric, and the measurements would add up to that as well. So I think the adaptor supplied is the wrong one and I therefore need to buy an adaptor to 3/8". My problem is I have no ideal what the other end of the adaptor is. It has a concave seat, has a finer thread than metric or UNF, and is about 9.7mm dia over the thread (again see the photos). From the web it seems like it could be JIC or NPT - any ideas?
Clive
