vibration, dolly1850 auto.
dollyman
#1 Post by dollyman »
hi all, i am new to this forum and asking for help :D
i have a vibration that i can feel in the car :( its not bad enough to shake the rear view mirror, but its there all the time.
i have checked the prop ujs and the centre bearing for play, and there is none at all!
plus there are no rust signs around them.
the car is a 1972 with only circa 26k on the clock.
the car has been fully polybushed, could this be the cause?
thanks guys any help would be appreciated :)
cleverusername
Re: vibration, dolly1850 auto.
#2 Post by cleverusername »
dollyman wrote: Thu May 18, 2017 12:35 pm hi all, i am new to this forum and asking for help :D
Polybushes could be your problem, from what I understand, they come in different ratings. From similar to standard bushes, to rock hard. It is possible that could be your issue, especially if they are the firmer bushes. I have read other owners regretting going for full polybushing.
markas
#3 Post by markas »
Could be the engine or gearbox mountings. I acquired a 23,000 mile 1500, 1977 vintage, last December. First job was to replace all three engine mountings which had gone all floppy in the last 40 years! Made a very noticeable difference to the noise and vibration.
1980 Dolomite 1850HL Auto
1977 Dolomite 1500
#4 Post by Carledo »
If the vibe is present when the car is stationary, it's not drivetrain!
I too would be looking at engine and gearbox mounts, they get oil soaked and go soft and saggy with age leading to the engine or exhaust sitting on the rack or crossmember/subframe. This is more than enough to give you bad vibes!
Triumph1300
#5 Post by Triumph1300 »
Is this vibration all the time, or only when moving?
If when moving, again all the time, or any specific speed?
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
olr159w
#6 Post by olr159w »
Just something to think about as I've recently gone through something similar.
I've replaced my engine and gearbox mounts because the sag was sufficient that the engine rested on the steering rack mounts on one side. I also suspect the original OS mount was upside down making it a lot worse.
So take a look at your relative engine position esp wrt oil pimp and steering rack
rgds
#7 Post by tony g »
Also, have the rear wheels been balanced? Rears out of balance can give the vibes through the car. Mounts are worth looking at though as mentioned. :)
dollyman
#8 Post by dollyman »
hi guys, many thanks for the replies :D
i have checked the engine mtgs, and they are perfect, likewise the gearbox mtg.
they are all clean and dry with no oil leaks! (must be a first on a dolomite!!)
yes there is oil in everything :lol:
there is no vibration when when running and stationary.
there are four brand new dunlop tyres fitted and balanced.
it is there from 10mph upwards, and like i say its there all the time but not bad enough to shake the rear view mirror. you can feel it through the car.
there is also a very slight diff whine, but not half as bad as the mrs :lol:
so, any ideas? where to go next? the poly bushes are yellow in colour if that means anything?
thanks again.
Mahesh
#9 Post by Mahesh »
The rearview mirror does not shake, but you can feel it when moving.
Does the feeling come from the steering wheel or seat ?
dollyman
#10 Post by dollyman »
Mahesh wrote: Sat May 20, 2017 1:00 pm The rearview mirror does not shake, but you can feel it when moving.
hi, from the seat.
Mahesh
#11 Post by Mahesh »
Someone may know better, but the seat is bolted to the floor, if it vibrates, so does most of the car.
Tighten seat bolts down, and check the floor hasn't rusted through.
dollyman
#12 Post by dollyman »
hi, no the seat bolts are tight and the floors are in mint unwelded condition.
it feels like the engine is bolted to the body, but there is no vibration at all when not moving :?
Mahesh
#13 Post by Mahesh »
Well, seems like most of the basics are covered,
I would say give it a very slow drive, (2mph) and feel if it's at all lumpy
or for a rhytm, and also go slowly round a (vacant) roundabout and check
for lateral movement, (preferably an empty car park, that way you can go
both sides).
dollyman
#14 Post by dollyman »
will do tomrrow, thanks again :)
grahamwatson
#15 Post by grahamwatson »
I have recently cured a similar sounding vibration on another classic (Volvo Amazon) by correcting the prop shaft phasing. This involves making sure that the front and rear yokes are in the same orientation, and have not gone "out of phase" by being incorrectly reassembled at the central spline.
Not sure if this is relevant on a Dolomite but it is a simple fix and may be worth a try if your yokes are not aligned.
