Mahesh
#751 Post by Mahesh »
Good point,
I'll put an ad in the wanted section,
Clear ABS Dolomite bonnet needed :lol:
Mahesh
#752 Post by Mahesh »
Finally got round to road testing the car on Tuesday.
Prior to a lot of fettling with the carbs, there was not much power in the mid and upper ranges.
The rear carb is now set two flats richer than the front (because the novelty vacuum gauge is stable at that point)
orignally I had used a caliper to check the heights on the jet and bridges to match both together.
Drove up to Stourbridge at motorway speeds, with no problems for 3 hours of driving, after which Carledo Steve
tested the car on country roads up to 90kmh ( :wink: ) again with no problems other than the brakes not being up to
scratch, (time for a TJ conversion).
The return to London, was a 5 hour trip due to restrictions and traffic, no problems again :D
Nearly there, just a little more work to do,
TJ brake conversion,
Engine rear bearing seal,
Axle diff gasket,
Half shaft seal,
New sump plug,
Sump gasket,
Front brake hoses,
New complete clutch,
Prop centre bearing,
Convert back to tandem brake system
Front shocks,
Front lowered springs,
Three (less rusty) doors,
Rear left wing,
Front valance,
I've got a list of the rest somewhere.
#753 Post by Carledo »
Mahesh wrote: Thu Jun 01, 2017 1:00 pm
Axle diff gasket,
Half shaft seal,
New sump plug,
Sump gasket,
Front brake hoses,
Front shocks,
Rear left wing,
Front valance,
Say it quick and it sounds like only a weekends work!!!!! :twisted:
Good to see you again mate and glad you got home in one piece!
Mahesh
#754 Post by Mahesh »
Took the brake servo off for a clean up and quick look, the bulkead
needs just a quick wipe,
Mahesh
#755 Post by Mahesh »
Nearly there,
new to this
#756 Post by new to this »
Mahesh wrote: Thu Jun 08, 2017 9:24 amNearly there,
Mahesh
Ive got the same thing to overhaul the servo,how do you get the white plastic hose joint out of the servo ?
Thanks Dave
Mahesh
#757 Post by Mahesh »
I carefully levered it out with two screwdrivers, had I known the design of the grommet, I would have just pulled it out by hand.
Will put a pic of the one way valve and grommet on tomorrow morning, makes more sense then.
new to this
#758 Post by new to this »
Mahesh wrote: Thu Jun 08, 2017 9:48 pm I carefully levered it out with two screwdrivers, had I known the design of the grommet, I would have just pulled it out by hand.
#759 Post by MIG Wielder »
Hi Mahesh, How did you get that excellent polished steel finish from the rusty paint original please ? It looks great.
More than just a wire brush and a Black & Decker I suspect.
Thanks ,
Mahesh
#760 Post by Mahesh »
Thanks Tony, Ryobi drill and wire wheel brush attachment only,
it's a shame I cant do more to loose the pitting, just have to paint over.
And a pic of the one way valve and grommet,
new to this
#761 Post by new to this »
Mahesh wrote: Fri Jun 09, 2017 11:07 am Thanks Tony, Ryobi drill and wire wheel brush attachment only,
Mahesh
thanks for photo,to lose some of the pits in the servo,try etch primer and then primmer filler before you put the top coat on,im going to try engine paint on mine,not striped mine yet that's a job for tomorrow :) :)
GlenM
#762 Post by GlenM »
Just skim it with body filler to loose the pits.
Mahesh
#763 Post by Mahesh »
Thanks guys, but only a simple paint over for now.
But while the servo is out, I might as well put in the throttle
pedal strenghtener from Alun.
Luckily for me, my bulkhead has a grommet in the third hole,
so no need to drill :)
I haven't put the pedal on the other side yet, the bolts are merely for
the picture.
2017-06-20 20.15.11.jpg (246.84 KiB) Viewed 2902 times
new to this
#764 Post by new to this »
Mahesh wrote: Tue Jun 20, 2017 8:20 pm Thanks guys, but only a simple paint over for now.
the picture.
have you got that plate on upside down ?
P.s not taken my servo out yet,do i have to remove the parcel tray to gain access to the servo
James467
TDC Sprint Registrar
#765 Post by James467 »
Na he's cool.... and the plate's on the right way up. You can see it on RUK being an auto which is what the plate is based on I believe.
You can get the servo off without taking out the parcel shelf. However, if you have strong manly hands like me access is rather tight! :wink:
