As title, where can I get half shaft seals and pinion seal for Sprint axle?
Axle oil seals, where from?
- gmsclassics
Re: Axle oil seals, where from?
I've never had to replace a diff pinion seal (100898) but have replaced the oil seals at the end of the axle tubes (that keep the oil in the axle) in all my cars. I've used the gearbox nose seal (141756) in place of the standard one and never had a problem since. This is better than the standard one fitted. I've just got these from Rimmers, along with the outer hub seal that requires the bearing to be pressed off to get at.
Geoff
Geoff
Thanks Geoff, do you mean the g/box nose seal fits the axle tubes?
Its ok I found a thread on it where you've already explained
Tony, Canley Classics have most of the seals on shelf as long as you have the ref number etc, when I did rear hub seal on the 1850 they had all the seals for rear hub and can still collect there as well most days!
Rich
Rich
1981 Dolomite 1500 Auto
Cheers Rich I'll see what I can do locally. The seals appear to be 1.25" x 2.00" x 0,5" so I may try a local bearing/seal place
- Yellow Banana
Similar problem is now evident on my Sprint (oil seepage from axle into brake drum) so looking to buy the gearbox nose seal (141756) instead of the proper inner axle hub seal (58800). However, Rimmers don't list the 58800 inner seal (or the 58801 outer seal) but do list two other seals - 109543 (£5.70) and 103811 (£5.26). Which one is which?? Also at this price neither are that much dearer than 141756 as was mentioned earlier
Now we have access to a wholesale account 141756 is something the Club could carry...
