Sequence of ignition Leads
ham204
#1 Post by ham204 »
Is this the correct sequence?
1972 Spitfire MK IV
1972 Stag
1980 Sprint
1962 Land Rover Series 2a
1983 Land Rover Series 3
1995 Suzuki Samurai SJ413
Re: Sequence of ignition Leads
#2 Post by Mad Mart »
You can put the leads in different sequences but this is the original order.
ham204
#3 Post by ham204 »
Damn, I didn't get one pot lead right!
Thanks for showing me the way
1972 Spitfire MK IV
1972 Stag
1980 Sprint
dursley92
#4 Post by dursley92 »
This is how I did mine, by marking how the old leads came out.
Interesting its the same way as ham204 and the distributor looks to be in the right way?
Russ Cooper
Dursley
UK
#5 Post by soe8m »
dursley92 wrote: This is how I did mine, by marking how the old leads came out.
You have the shaft 180 degrees out and had it corrected by having the leads 180 degrees out again.
Mahesh
#6 Post by Mahesh »
soe8m wrote: Thu Jul 20, 2017 6:41 pm
But that means, two wrongs make a right !
Good info, I need to check mine.
dursley92
#7 Post by dursley92 »
Jeroen, thanks for that information about the jackshaft being 180 degrees out.
The engine is just as I bought it 5 years ago so it seems whoever built it put it together wrong. Now I know not to copy it!
Russ Cooper
Dursley
UK
#8 Post by soe8m »
Distributor shaft. You can pull the dizzy out, turn by the rotor 180 degrees and push it in again. Have then the leads in the original way.
But you can leave it as is. It's just a detail and probably thousands of cars do have this. Originally when cil one is on fire the rotor tip has to point to the lower manifold bolt. Your's is put in this way when cil 4 is on fire.
