Sloppy Gear Lever
Neil Duke
Sloppy Gear Lever
#1 Post by Neil Duke »
Is there a quickshift kit?My gearlever is very sloppy,I know its not a Ford,but it could be better.
Hello and .....
#2 Post by sprint95m »
Welcome to the forum.
Which model of car have you got?
There are several gearboxes used.
PS I have moved this to "Dolomite Related" as this is a more used section of the forum.
Neil Duke
Re: Sloppy Gear Lever
#3 Post by Neil Duke »
Sorry,79 Sprint.
#4 Post by xvivalve »
The Sprint gear lever is secured with a sprung bayonet cap that is then secured with a bolt. I have seen cases where the bolt missing can cause the bayonet cap to undo itself; I have also seen cars reassembled without the spring beneath the cap, both of which can cause a lose stick, or even the end of it to jump out of the remote box. The end of the stick has a small blind hole that receives a sprung plunger; this is more often than not missing as it is a right bugger to install correctly, but that itself causes minimal slop.
Correctly assembled, the Sprint stick should be tight and fairly precise; I suggest you lift the coin tray and rubber gaitor and see what is amiss. I've had some very high mileage cars but never found one with an unduly worn stick or selector rods in the remote box.
Neil Duke
#5 Post by Neil Duke »
Thanks,will check tomorrow night.
#6 Post by xvivalve »
Neil, my apologies; welcome, I didn't notice this was your first post!
Is the car a recent acquisition?
Neil Duke
#7 Post by Neil Duke »
It is.Just trying it for size,bought it off e bay.I have got a Stag in the garage,& fancy getting a TR6 as well.Funny,my race cars are all Ford.
Probably be back with lots of silly questions.
