Internal rust - Sprint fuel tank
Re: Internal rust - Sprint fuel tank
Hello Clive, Welcome!
Have a look at James's restoration thread for RUK, he had similar tank issues and successfully dealt with it at home, it starts partway down this page:
viewtopic.php?f=19&t=32242&start=45
- TDC Cheshire Area Organiser
Hi Clive, yes welcome to the forum
If you dont get any luck using the bilt hamber stuff?
I do know of a chap who makes fuel tanks out of aluminium, but only to a pattern, ie "old tank"
I know he made one for a friend (not a dolomite) and he made an excellent job, even to the right threads for the sender unit.
Cheers, Tony.
Cheers, Tony.
NOW A CLUB MEMBER 2017057
- NickMorgan
Hi Clive,
Welcome.
I have had exactly the same issue with my 1300 fwd. I managed to get it 62 miles towards home before it cut and I came home on the back of a recovery truck. Blowing back down the fuel line sorted the problem temporarily, but I intend using a Bilt Hamber kit over the winter (once I have sorted out all of the other issues!).
Nick
Welcome.
Nick
Thanks Photobucket
- SprintMWU773V
- TDC Staffs Area Organiser
I once used a tank sealer product in my tank. Despite being careful to prepare the tank it ended up failing and it flaked off blocking the lines. I ended up swapping out to another tank. I have used a new tank in my car now, though if and when it rusts out I think I'd get one made. It's not original but it's hidden so who cares. There's so few decent used tanks around now that this might be the only way to go.
I haven't got round to checking the tank on my rebuild yet, but if it's dodgy there are a couple of metal fabricators near me who are willing to copy items, so I would try them for making a replica. There must be similar folk near you. Try googling for metal fabricators or blacksmiths in your area.
The Club delivered patterns of the three types of tank our cars use to Alicool about 6 months ago...but they've been a little slow at coming back with prices. Conversations so far have revolved around rationalising the shapes for ease of construction...meaning the volumes will be smaller, and postulating incorporating modern in tank pumps. If anyone has a specific tank maker contact, we'll be more than happy to talk in tandem...
We have the same old problem that we have with panels; the OE tanks relied on a couple of pressings each which we cannot economically reproduce in the numbers that demand will allow.
Good to hear, I was about to ring Alicool to see if they could do me a tank.xvivalve wrote: ↑Sat Sep 09, 2017 9:40 am The Club delivered patterns of the three types of tank our cars use to Alicool about 6 months ago...but they've been a little slow at coming back with prices. Conversations so far have revolved around rationalising the shapes for ease of construction...meaning the volumes will be smaller, and postulating incorporating modern in tank pumps. If anyone has a specific tank maker contact, we'll be more than happy to talk in tandem...
Had a similar problem with my Toledo - the original tank had rotted out, the previous owners had sourced a rusty (leaking) but repairable tank, and fitted a temporary smaller plastic tank for the time being.
The steel (OEM) tank had been empty for a while and well ventilated, so we felt happy (enough) welding it. Cut out the rusted bottom, dressed the steel back and made a new repair plate, welded it in (about 1/4" overlap all round). The overall shape is very close to the original though the pickup pipe is not a trifle shorter and has lost the in-tank support.
I then painted it - with several coats on the bottom! - and a 2-pack epoxy lining treatment inside. A couple of hundred miles in, no sign of leakage.
Good luck with yours. Is it worth thinking about welding? If it's been empty enough to get rid of all the petrol vapour, it's (fairly!) safe to weld. I still have my eyebrows...
If it works and lasts, £200 isn't so bad. Keep us updated over the next few weeks, months, years.
