WHAT OIL?
D16PJM
WHAT OIL?
#1 Post by D16PJM »
Hello i have done a search and as im useless not found anything but what is the best oil to put in a 1500 dolly.
Thanks Pete
tamtrucks
Re: WHAT OIL
#2 Post by tamtrucks »
loads of different makers of oil,,,i use millers 20/50 for the last 8 years in triumph`s,very good all round,,but thats me and my experience
Flyfisherman
Re: WHAT OIL
#3 Post by Flyfisherman »
Pete
A few on here swear by Millers, I prefer Castrol Classic but i have a can of penrite to try.
More forum members will voice their opinion.
Paul
D16PJM
Re: WHAT OIL
#4 Post by D16PJM »
So 20/50 is the way to go, i was confused as looked on opie oils and showing semi synthetic which seems wrong for a 70s car.
Thanks Pete
tamtrucks
Re: WHAT OIL
#5 Post by tamtrucks »
try to get mineral oil based.dont know if you can use other formula,ive never tried so cant say otherwise,but ever since i had triumphs ive used millers 20/50 mineral oil,recommended to me by good mate who works at triumph resto`s near me :D
Re: WHAT OIL
#6 Post by Toledo Man »
The make isn't too important as long as it is a decent brand. Like others, I swear by Millers myself and some use their 20W60 classic oil.
Bumpa
Re: WHAT OIL?
#7 Post by Bumpa »
If you email Opie oils with details of your car they will tell you which oils are most suitable, engine, gearbox and diff. I did this for my BMW Z3 and much to my surprise they recommended a 50/50 mix of MTF and ATF in the gearbox. The gear change has noticeably improved having followed their advice. Good company with a great selection of oils and quick delivery.
dollyman
Re: WHAT OIL?
#8 Post by dollyman »
What ever make you buy, make sure it is not in a "gallon" can such as stuff sold in halfords and other places branded "motorway" it is "reclaimed" oil and not fit even for door hinges :wary:
It is totall POO :(
I always use "morris" oils and have had no problem :D
Cheers, Tony.
Re: WHAT OIL?
#9 Post by soe8m »
Try zddp on the search function. Very much needed with the camshaft next to the crankshaft.
Re: WHAT OIL?
#10 Post by Jon Tilson »
As Jeroen says the ZDDP additive is crucial for cars of classic vintage...ie the 70's and earlier.
You need to check the API rating as well as the viscosity. You need something around SJ and nit too much higher.
10W 50 will give easier starting in winter.
Valvoline VR1 is good. Comma also do a decent API rated 20W 50.
cliftyhanger
Re: WHAT OIL?
#11 Post by cliftyhanger »
And to add to the above, the biggest reason for not using synthetic oils is that there may be an inch of tar-like crud in the bottom of your sump (I have seen that often enough) and synthetics are far more likely to start breaking it up, and you do not want that floating about.
As to recommendation, it largely depends on how you use the car. If you don't do long motorway runs at high speed, or otherwise thrash the car,then any branded 20/50 will work. If you drive the car hard, you WILL need something better, I would happily recommend millers css 20/60, but it is 3x the cost of an OK oil.
And beware the 1500 if you intend driving it hard. Ask more if you need to!
Bumpa
Re: WHAT OIL?
#12 Post by Bumpa »
Oh yes! When I took the sump off my 1850 I couldn't believe the amount of sludge in the bottom of the pan. It really was at least a half an inch thick. Nice and clean now, and with new bearings etc, I might end up using a semi-synthetic. Opie recommends a 10W-40 for the 1850 engine. Surprisingly to me, they recommend the same type and grade for the 1500 OHV engine as well.
Re: WHAT OIL?
#13 Post by soe8m »
I would immediately stop believing opie then. A 40 is too thin.
Jeroen.
SprintMWU773V
TDC Staffs Area Organiser
Re: WHAT OIL?
#14 Post by SprintMWU773V »
Very few if any manufacturers will post the ZDDP content so you need to get clever. Look at the safety data sheets for clues and also the API code. The very new ones have very little in as it damages catalysts so you want something like an SF or SG, no later. Nothing wrong with mineral oil, just doesn't last as long in service.
Oddly you'll find many 'classic' oils like Halfords and Comma (they make Halfords) and Castrol is usually quite an early API so you're probably better off going for something like a Valvoline or a Millers which has the benefit of better anti-sludge additives and a decent level of ZDDP. Incidentally too much ZDDP is also bad so don't go adding more.
I echo other comments on Opie oils, their recommendations suck, they always recommend too thin an oil in my experience. Stick to what the car manufacturer says for road cars and you won't go wrong.
My other top tip, depending on the grade of oil you need is look at some of the agricultural machinery oils. I recently had cause to buy some 10w30 which is a rare grade in the UK. I could buy any amount of motorcycle oil which has additives for wet clutches so no good for a car, eventually opting for some Millers Superfleet which is a good old mineral oil for tractors and diesel engines. Fits the specs I needed just perfectly, only down side was having to buy 25 litres but upside it's also suitable for my lawnmower!
dollyman
Re: WHAT OIL?
#15 Post by dollyman »
I will second that above, a 10/40 is way to thin and will contain much more detergent :?:
Do they offer a free engine rebuild?
