Rear Fog Lamps
Rear Fog Lamps
Does anyone have a photo of the original type of rear fog lamp fitted to the late Dolomite, or the make.
All help appreciated.
Club Membership No: 2017092
Re: Rear Fog Lamps
They were a dealer option fit until they became law in 1980 when the cheap Lucas type were used.
Same as this......................
https://www.ebay.co.uk/itm/CLASSIC-CAR- ... SwYwJZ~HdB
Re: Rear Fog Lamps
Thanks, is that the only type that were fitted?TrustNo1 wrote: ↑Thu Nov 09, 2017 8:22 pm They were a dealer option fit until they became law in 1980 when the cheap Lucas type were used.
Re: Rear Fog Lamps
Not 100% sure but as it was only law after April 1980 it was only the last year of production that had to have them I can't see Triumph spending money buying from other sources. I certainly haven't seen any other type on very late ones, the boot shape doesn't give to any flush fit type.RSi wrote: ↑Thu Nov 09, 2017 8:27 pmThanks, is that the only type that were fitted?TrustNo1 wrote: ↑Thu Nov 09, 2017 8:22 pm They were a dealer option fit until they became law in 1980 when the cheap Lucas type were used.
Re: Rear Fog Lamps
I have 2 on mine, one looks like stock but no make on it - probably safe trying to find 2 Lucas ones that have the bumper fitment.
Re: Rear Fog Lamps
There were several variations fitted, but all similar; some had a black plastic back, some had a 'chrome' plastic back...
Re: Rear Fog Lamps
I've found a view Lucas options on the net so will probably get the closest.
- TDC Cheshire Area Organiser
Re: Rear Fog Lamps
Radyot made them as well, but more oblong than lucas.
I think they look better
But that is because i have them on my car
NOW A CLUB MEMBER 2017057
Re: Rear Fog Lamps
Have you a photo of them?
Re: Rear Fog Lamps
I will try and send photo
There is one on ebay at the moment item, 372101543729.
Very easy to fit, mine are on the bumper bolts.
Cheers, Tony.
Cheers, Tony.
- IMG_1037_1.JPG (70.49 KiB) Viewed 2214 times
- SprintMWU773V
- TDC Staffs Area Organiser
Re: Rear Fog Lamps
Mine are Raydyot. You can sometimes find them on Ebay. I used some metal brackets from Wickes, cut them down slightly, sprayed them black and then fitted the lights to the brackets.
Re: Rear Fog Lamps
That's a great help guys, just to search for 2 suitable ones now.
- SprintMWU773V
Re: Rear Fog Lamps
There's a couple of Raydyot on Ebay currently, though they aren't hugely cheap. I think mine cost £15 for the pair, now people are asking double that for 1!
Re: Rear Fog Lamps
Typical, I'll hang out for better deals as don't need them immediately.SprintMWU773V wrote: ↑Fri Nov 10, 2017 11:40 am There's a couple of Raydyot on Ebay currently, though they aren't hugely cheap. I think mine cost £15 for the pair, now people are asking double that for 1!
