Remembering a few things, I tried Jeroens "trick" of trying to ratchet strap the front of the front tyres together. Result, change of 12mm in tracking
After some faffing about, there is some play in the offside rack inner balljoint, and the nearside rack tube bush
Looks like the "recon" rack fitted a mere 20,000 (hard) miles ago is more con than recon.
Turned attention to the rear. Since I fitted Dolly 1500 rearsprings the car has felt skittish at the rear. So dropped the shocks, and took the springs off.
I then measured them open, and the original toledo rear springs. 20mm difference. I then placed a block of wood on each, and allied my approx 160lbs of weight. Both reduced in length by 30mm, so both springs must be 145lb/inch or thereabouts. I also checked some short springs I had, and they changed by 25mm, so about 160lb/inch. I also have some 25mm spacers...
Anyway, I decided that the car used to handle well with the old springs, but had a tendency to bottom out on rallies. But better that than the skittishness. So swapped back to the std toledo springs.
As a swerveball, I also changed the MGFwheels shod with Michelin E3B 185/55/15 to my trusty Falken 185/60/13's on GT6 5.5j rims.
The result. Skittishness gone! I could try the big wheels again, see if they are the issue, but my gut feeling is it is the springs. But no idea why as 20mm difference in height should not make the difference??
In other news, the std axle tie rod bushes (152767) that I fitted 14 months ago are cracking up badly. Well, 2 are, one each side.
Not wanting to fit any more cheap and fally aparty bushes, what is the consensus? I think polybush may be too hard?? is that right? What are the best to use??
And I think I need to ask about a recon rack....
