Carb/airbox rubber bobbin
- SprintMWU773V
- TDC Staffs Area Organiser
Can anyone advise the size or even where I can get one of the rubber cotton reel bobbin mounts that fixes to the carbs and helps to dampen the air box and fuel line? Mine has long since disintegrated. I don't imagine they are hard to find but have no idea on the size.
Re: Carb/airbox rubber bobbin
http://www.avindustrialproducts.co.uk/d ... obbins.pdf
the original thread is 1/4 unf, unsure of the thickness of the rubber but I believe it is about the 1/2 area,
Malcolm
Malcolm
- TDC Cheshire Area Organiser
I dont know the size, but Peugeot and Citroen use similar on the plastic cover that sits on top of the engine under the bonnet so might fit?
Cheers, Tony.
Cheers, Tony.
NOW A CLUB MEMBER 2017057
- Triumph1300
Or airhead bmw motorcycle battery box mounting Robbins, try motobins, or motoworks
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
The Sprint one is the same as the 1850 : UKC2451. In fact its a very common Triumph part on the Stag / 2000 / TR% /TR6 etc; etc; Moss have them currently.
Or fit club solid alloy mounts, no need for the bobbin. (well, on an 1850 for sure, dunno about Sprint?)
- Flyfisherman
MarkSprintMWU773V wrote: ↑Wed Nov 22, 2017 10:07 am Can anyone advise the size or even where I can get one of the rubber cotton reel bobbin mounts that fixes to the carbs and helps to dampen the air box and fuel line? Mine has long since disintegrated. I don't imagine they are hard to find but have no idea on the size.
sizes are viewtopic.php?f=4&t=32265
Paul
- SprintMWU773V
Super stuff thanks
