Sprint wheel nuts
Sprint wheel nuts
How do you make your Sprint wheel nuts presentable.
Club Membership No: 2017092
Re: Sprint wheel nuts
Has anyone ordered from them, anywhere closer to home.
I typed Wheel Nut Caps into ebay and found hundreds of them, in all colours and finishes. For my 1850 Dolly with Sprint wheels the 17mm is the size. For my MGB I need the 19mm. Just measure the nuts across the faces with a caliper.
So it's 17mm, brilliant - try it and see what It's like.
Has anyone seen chrome wheel nuts on a Sprint? And what does it look like.
I often wonder if cavalier/astra push on bolt covers would work. (17mm) or were they 19mm?
Yes early ones were 17mm some here cheap as chips used to be
https://www.ebay.co.uk/itm/17mm-Wheel-N ... SwH09ZJn2O
- SprintMWU773V
- TDC Staffs Area Organiser
I did try to have some re-anodised but the original coating was too good and would've dissolved the nut before the coating! Probably just end up painting them
Available as 11/16" covers,
- s-l225.jpg (12.04 KiB) Viewed 3581 times
- file-1.jpg (12.04 KiB) Viewed 3572 times
Spikey !
Wheel nut covers.
Unfortunately only in chromed plastic, would have liked stainless steel or titanium.
- trackerjack
Klu klux krome
Ladeees and Genulmenn, I give you, the one, the only, MAHESH!!!!! Undisputed bling king of the TDC forum!!!!!
PS, Do they do matching valve caps for those nut covers mate?
- TDC Cheshire Area Organiser
Did"nt James Bond have something like these on his car to get rid of the "baddies"
NOW A CLUB MEMBER 2017057
Madonna's nipples?
