New member- 37 years on
GTiJohn
Re: New member- 37 years on
#16 Post by GTiJohn »
xvivalve wrote: Tue Dec 26, 2017 6:19 pm ...it would be interesting to know how close to the 'changeover' the chassis number is...?
16727
When was the changeover?
I know that the introduction of new parts was rather piecemeal back then so I'm not surprised if it's on-the-cusp.
Is it possible that Triumph were using up old stock with this colour combo?
After 37 years I've finally got my hands on a Mimosa Sprint :-)
#17 Post by xvivalve »
Change overs were at 15001 and 18278, so it is right in the middle of the second series, built sometime late 1975...
I don’t suppose it came with a Heritage Certificate?
GTS290N
#18 Post by GTS290N »
Late '75 is spot on with the 'hybrids' my September 75 1850 has the seats with blanking plugs for headrests, later exhaust, earlier badges, single rail box.
GTiJohn
#19 Post by GTiJohn »
The strip down has started. The nearside headlamp mount being much worse than the offside.
Not surprised to find the standard 70s newspaper-and-filler bodge with 'The Star' dated 29th June 197?, so likely to have been repaired within 3 years of it going on the road,
Are metal upper front panels like rocking horse poo by any chance?
Emerald Sprint
#20 Post by Emerald Sprint »
There's rebuilding and there's Rebuilding... Great that you're set to reanimate this one, good luck!
Greetings,
Joris
Galileo
#21 Post by Galileo »
Nice amount of overspray on the radiator from a previous 'repair' there as well! Good luck with the work.
#22 Post by xvivalve »
You have one early and one late side light assembly!
They are, though if you know who to ask, you may find one at a price! 😉 (I did have two, but sold one a few weeks ago...) Alternatives exist in a full GRP front at £145 collected (£175 delivered), or metal repair sections (Type K), but these require some work and skill to set in.
GTiJohn
#23 Post by GTiJohn »
I'll be adding a K (or 2) to my list :-)
I have the other matching lens in the boot already. How do the reflector/bulb holders detach from the wiring harness? The earth wire is easy but I'm trying to work out which bits to pull or twist and how hard.
Found out that 29th June was a Friday in both 1973 and 1979 - my money is on the latter !
#24 Post by xvivalve »
If you follow the wires back along about 2 foot you'll find either a three pin connector block or three separate bullet connectors.
29 June?
GTiJohn
#25 Post by GTiJohn »
xvivalve wrote: Mon Jan 08, 2018 11:37 pm
29 June?
Thank you I haven't got that far back yet,
29th June 1979 is the likely date from the newspaper removed from the bodge
#26 Post by xvivalve »
Ah, I re-read your posts looking for the reference, but it was hiding between two photo's!
GTiJohn
#27 Post by GTiJohn »
Indicators and front spoiler now removed. A couple of the bullets backed out from one of the connectors but it looks like they'll all need a good clean-up anyway before they go back together.
Regarding the mismatch of indicators - which one are the right ones for my vintage of car? I've been told it may be linked to the type of hazard switch fitted, which is the pull-type on mine, (VA no. is 16727 to save you scrolling :wink: )
mahony
#28 Post by mahony »
Looking at the front of your dolly the indicator lens on the left is the correct one for your vintage , the earlier ones are actually better as they have a rubber boot on the back of the lens which keeps muck out, hence me converting to the earlier type :wink: :)
GTiJohn
#29 Post by GTiJohn »
mahony wrote: Sun Jan 14, 2018 5:01 pm Looking at the front of your dolly the indicator lens on the left is the correct one for your vintage , the earlier ones are actually better as they have a rubber boot on the back of the lens which keeps muck out, hence me converting to the earlier type :wink: :)
I've got 2 of the newer ones now so we'll see how they go :)
GTiJohn
#30 Post by GTiJohn »
I've been digging a bit deeper...
I've got one of the repair panels
But I'll be needing the other one too
At least the car will weigh substantially less when I've finished!
