Hi Everyone After several years of building an MGB GT to my own particular taste , that is power steering, sitting higher to make it easy to get in etc. I now find with ageing hip joints, even with the mods its getting hard to climb out of it. So looking back at the cars I enjoyed, the Dolomite came to mind. My first was a 1 year old Sprint in 1978 followed over the years by 2 1850's. Anyway found this 1980 1500HL auto in Falmouth, 1 owner, garaged all its life, every mot, completely rust free and almost original except for a bottom half respray following a dented door and with side strips unavailable they were all removed. Virtually everything mechanical has been replaced over the years and all work. The car runs faultlessly and I can get in and out effortlessly. Its a joy to drive. May look for some Sprint wheels to give it the looks. If you are wondering why my Suzuki is sitting on its ass, it is because the Dolly boot is full of spare plus some on the rear seat and the Suzuki boot has an auto box , torque converter, flywheel, diff, propshaft, bumpers and several boxes of assorted spares. I new there were a few spares but expecting the mountain that was collected over 37 years (just in case they were needed). As a matter of interest apparently it was recalled by BL in 1986 and the flywheel was replaced.
You will love the Dolly auto I was never a fan of auto's at all, but after spinal surgery i can no longer press a clutch
I just wished i had swapped earlier, old age i suppose
do you know if the gearbox oil and filter has been changed at all?
also be careful to use the correct fluid in the box you must use ATF-G or Ford spec M2C-33G, Andrew Page auto factors have it on the shelf.
I run sprint wheels with 175/70 tires on my 1850 auto and it does affect the engine revs, for the same road speed my engine runs 300 RPM higher. perhaps I should use non low profile tyres instead.
Magenta Auto Sprint wrote: ↑Thu Jan 18, 2018 7:37 am
good to see another auto on here.
Enjoy the Dolomite.
Malcolm
The circumference of a 175/70 sprint tyre is 99.5% of that of a 155/80 1850 tyre, so I doubt it would make that much difference.
I have checked the oils, both engine and box look clean and fresh, the engine oil filter looks new. No way to check the box filter without dropping it out. The changes are surprisingly smooth. I have never bought a car that has been so well looked after. I think the previous owner was so fastidious, it has probably been cleaned or replaced. Thanks for the advice guys.
