FWD 1300 steering part problem
TrustNo1
Re: FWD 1300 steering part problem
#1 Post by TrustNo1 »
Usual method is with most donut shape Poly bushes is to compress them first before fitting, with the smaller ones I put them in a vice overnight or you can use longer bolts to fit them then chnge the bolts after a day or so.
