Tank venting
AlanH
Tank venting
#1 Post by AlanH »
I would like to pick up on what Richard said in a previous post.
I have had the front carb off my latest 1850. I left it overnight only to find a strong smell of petrol in the garage. When I looked petrol was spewing out of the pipe that goes to the float bowl.
I took the fuel cap off, there was a large rush of air and the flow stopped.
The cap was was the locking type so I assume that, as Richard said, the tank vents through the cap and my one was air tight.
I'm not sure how the tank venting works, if the tank breather pipe just connects to the filler tube then what use is it?
I have an original that I can use for now but I would like a locking one so I wondered if it possible to vent the one I have, perhaps by drilling a small hole. If not does anybody know of a supplier of vented caps?
Re: Tank venting
#2 Post by tony g »
The pipe that connects to the filler pipe is only for filling purposes. It stops the petrol backing up and clicking the pump off, so only works when filler cap is off. Locking venting caps should be available so worth a search. Was yours warm in the garage? Seems odd to have pressure in there as opposed to slight vacuum..
AlanH
Re: Tank venting
#3 Post by AlanH »
The garage is attached to the house so it is quite warm.
I did notice a slight intake of air when I took the cap off to fill the tank so I have assumed that the cap is not vented and vapours have created pressure in the tank forcing the fuel out of the pipe
Richard the old one
Re: Tank venting
#4 Post by Richard the old one »
I recently attempted to purchase a new locking petrol cap from Moss but it turns out that our petrol pipe / cap is not a common size that they hold.
What I have done in the past is cut a slot across the rubber seal in the cap. I believe the MoT man should check the seal but if he is knowledgeable he should know that it is needed to let air into the tank as petrol is drawn out.
RJF_70
Re: Tank venting
#5 Post by RJF_70 »
I too have this with my 1500 auto Dolly, always whooshes when cap removed, and when working on handbrake recently could hear a very slight hiss, remove cap and relocate and it stops. It too has a locking cap. Have tried making sure the vent is clear, may try like Richard says and cut a slot in rubber seal.
Cheers Rich
1981 Dolomite 1500 Auto
Re: Tank venting
#6 Post by tony g »
If you look at the standard cap, under the seal face there is a slot in the cap itself. The rubber covers most of it so its not obvious at first. If you can remove the rubber seal maybe a bit of filing or dremel to create a little gap that can allow air past it may be the solution. Gap doesnt need to be very big it only needs to allow air in at the rate the fuel is leaving.
Triumph1300
Re: Tank venting
#7 Post by Triumph1300 »
Also, there should be a copper washer under the seal
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
Re: Tank venting
#8 Post by tony g »
Yes good point about the copper washer Bruce. It stops the rubber squishing into the slot and closing it off :)
Re: Tank venting
#9 Post by xvivalve »
I have a limited number of second hand tried and tested locking caps
