Balancing and Machining Recommendation
Re: Balancing and Machining Recommendation
#16 Post by Carledo »
trackerjack wrote: Sat Jun 16, 2018 5:54 pm
soe8m wrote: Sat Jun 16, 2018 9:52 am
trackerjack wrote:
You are so right, about 10 years ago one block I noticed the pistons were not square to the face of the block!! Was it the rebore or was it like that from the factory?
No dolomite engineblock is square. The main bore is not square with the deck. My machineshop has a stand that clamps in the crankshaft bore and when skimming the deck is square again and all pistons have the same heigth. Also the front face is not suare. Every single jackshaft plate is worn at one side and not equal on the total surface. such a funny engines we have.....
So what you are saying Jeroen is that even the basics of engineering they could not get right!! :lol:
Which is what I have been saying all along :wink:
And people STILL ask me why on earth I go to the trouble of fitting a Vauxhall engine of similar output! :twisted:
#17 Post by soe8m »
Some think that's too easy.
Jeroen.
#18 Post by Carledo »
soe8m wrote: Sun Jun 24, 2018 7:18 pm Some think that's too easy.
Jeroen.
Too easy is good! I'm a big fan of the first law of engineering Keep It Simple, Stupid! AKA the "KISS principal"
The idea is to do some work at the beginning, then NOT have to keep doing it over - and over - and over again! So far, it has worked out well, I have a quick car that doesn't require endless tinkering and is still great fun to drive. What more could a petrolhead want? (apart from 20p a gallon petrol :twisted: )
trackerjack
#19 Post by trackerjack »
So in conclusion perhaps you can make a silk purse from a sows ear!
I am going to Swaymar tomorrow to balance a bottom end of a Sprint engine and I have an STR91 cam to put in it too!
mbellinger
#20 Post by mbellinger »
Thanks to everybody who replied.
I ended up going with MED. We hit an immediate snag in that they did not possess any 1098cc cranks to spin the assembly up on (the 1098 in line crank is unique and very different from the 1275).
This meant dropping my crank out of the engine :roll:
Still, work is now underway and I look forward to putting the thing back together now. We are aiming to get the car ready for Goodwood at the beginning of September, so lots to do!
I will start another thread on here as we rebuild the car as I suspect folk on here will be interested.
Martin.
2021 Dacia Duster 1.3 TCe
1963 Austin A40 Rally Car
