Fitting fuel pump
Stavo1970
Fitting fuel pump
#1 Post by Stavo1970 »
Hi everyone i have to replace my fuel pump on my sprint engine it is a sort arm one has anyone got any tips how to line it up with the cam as i always here of people having problems refitting would be very much appreciated cheers Steve
dursley92
Re: Fitting fuel pump
#2 Post by dursley92 »
I never understand how this can go wrong.
Just tilt the lever upwards as you enter it into the block so it goes on top of the cam and away you go.
Only awkward bit is holding the pump against the spring pressure until you can get a bolt done up to hold it in place.
Russ Cooper
Dursley
UK
dollyman
#3 Post by dollyman »
dursley92 wrote: Mon Jul 09, 2018 6:27 pm I never understand how this can go wrong.
I have seen people put the lever under the cam :shock: :shock:
Mahesh
#4 Post by Mahesh »
I put in a longer bolt first to assist in pressing to the block, once the second was in finger tight removed the long for correct bolt, worked for me.
AlanH
#5 Post by AlanH »
Sometimes the bolts are slotted so that you can hold them in with a screwdriver.
If not, put a magnet in the socket.
dursley92
#6 Post by dursley92 »
Mahesh wrote: Mon Jul 09, 2018 8:10 pm I put in a longer bolt first to assist in pressing to the block, once the second was in finger tight removed the long for correct bolt, worked for me.
I was just going to add that bit of advice Mahesh but you beat me to it.
Russ Cooper
Dursley
UK
Stavo1970
#7 Post by Stavo1970 »
Cheers everyone for the advice on fitting fuel pump steve
#8 Post by Mad Mart »
...or cut the heads off two scrap bolts (or use studding). Cut a slot in one end for a screw driver to fit. Insert the studs, install pump, use nuts to hold pump, replace studs one at a time with original, slotted bolts.
