Rear Hub oil seal
AlanH
Rear Hub oil seal
#1 Post by AlanH »
I am putting my half-shaft back together
I assume that the outer oil seal (GHS184) should fit snug around the hub (which it doesn't).
Can anybody confirm this.
AlanH
Re: Rear Hub oil seal - what size is your hub
#2 Post by AlanH »
I have measured the hub diameter at 33.5 (ish).
The seal supplied by Rimmers (GHS184) is 36 47 7
This is the same as the TR7 but Obviously is wrong.
Has anybody sourced these from any where else?
I have found a 32 - 47 - 7 and a 1 5/16 - 1 7/8 - 5/16 imperial.
Surely someone has fitted these before - where did you get yours from ?
RJF_70
#3 Post by RJF_70 »
When I did mine on my 1850 I bought the kit from Canley Classics, although I was only changing the hub seal. I still have the box containing Bearing, pin and another seal, it's a Trupart Wheel Bearing Kit TBK012 or as on box top GHK1007. The seal I have remaining has the numbers SC24 47 10
Rich
1981 Dolomite 1500 Auto
AlanH
#4 Post by AlanH »
Managed to get a seal that seems to fit.
33 47 8 . May be worth making a note of.
Galileo
#5 Post by Galileo »
You can use the gearbox nose seal on a Sprint axle for a nice tight fit though assume the 1300/1500/1850 shaft will be smaller diameter.
I buy my seals from:
Jonathan Welch
Oil Seal UK
sales@oilsealuk.co.uk
www.oilsealuk.co.uk
AlanH
#6 Post by AlanH »
Anybody got a recommendation for lubrication.
