RFF 861T Where are you now????
Having successfully finding and buying back my own dolly 1850 now 3 years on. A friend of mine Phil asked me about his own Dolly Sprint he owned in the 1980's and wanted to know there whereabouts of it and the possibility of being reunited with it
The reg is as said about RFF 861T, when Phil owned it, it was red, there a photo on the internet of it in yellow, but according to DVLA records its still taxed and MOT'd and is now green
https://hiveminer.com/flickr_hvmnd.cgi? ... o_type=250
Does anyone know where it is now?
Re: RFF 861T Where are you now????
Inca paintwork in very good nick in July 2017, be weird that someone would paint it green now, and after having being 'subject to a complete nut and bolt restoration completed over a 12 year period'!
https://www.carandclassic.co.uk/car/C884671
https://www.historics.co.uk/buying/auct ... te-sprint/
According to DVLA records its MOT'd but declared SORN
If anyone knows where it is can they get in contact
- maitretjak
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
My concern with the paint job would be that if it was painted just for the movie it may likely just be a very cheap spray over and not been prepped properly nor the door, boot jamb or under bonnet done.
Unlike with the older ads the ebay seller included an underbonnet shot and you're right, very yellow and not at all mellow! A massive fuel filter, an oil cooler in a very odd location and an interesting full width radiator arrangement with the fans on the opposite side.
So this car has been red then yellow then green
- TrafficLight.gif (98.82 KiB) Viewed 3404 times
Love to know how this clip was made! British traffic lights NEVER follow this sequence! You'd have had to take the green-returning-to-red sequence and reverse it!
Looks to me like a VERY skinny ally rad and TWO fans in front, one each side. I can't believe that oil cooler is particularly effective in that position, would be better with a row of louvres in the bonnet above it. Ad says the car has an electric water pump too, someone was obviously serious about defeating overheating issues!
Ah yes, made using the finest ingredients of a slice of 'power of the internet' together with the liberal application of 'artistic license' sauce to achieve a bad graphical pun.
Whats with the thermostat housing? Ive not seen one like that before
Probably from some other leyland vehicle. It wouldn't surprise me that a wrong thermostat fited was the start of fitting such an radiator and oilcooler. Or seeing those fuseboxes the last owner did forget to fit the gauge voltage stabilizer. Can't see no other reason why you would need all that.tony g wrote: Whats with the thermostat housing? Ive not seen one like that before
And what's with the earth lead on the NS turret?
It looks like the Speedo gauge is from a Stag they read up 140 where dolomites read 120
