While I've got the half shafts out of my rear axle on my Toledo I'm thinking that I might as well replace the rear wheel bearings. I've managed to pick up some NOS Unipart GHB180. I'd be grateful if someone can clarify the procedure. According to the ROM I have to press the bearing onto the half shaft at exactly 69.94mm. I am not sure how to measure that accurately.
James467 did a great howto saying:
"Pressed the new bearings onto the shaft to the specifications in the workshop manual. What happens is that when you tighten the hub up it draws the shaft through the bearing and ensures that it is positioned in exactly the right place to avoid extra load on the drum. Thanks Jeroen for explaining that!"
Does that mean that I should install the bearing short of 69.94mm? If so how much?
Many thanks.
