When i handed my V112 in at the PO she looked at it strangely then read it out loud, went ok and put it to one side, i am pretty sure it is probably still sat on her desk. Best bet is to get your car MOT'd every year and be thankful you pay no tax.
I wasn't saying that the garage would keep the record but you would or should. The garage would give you an invoice for a safety check proving you had at least done something to prove roadworthiness should it ever be needed. Many people across the country in car clubs are talking about this and quite a few are saying this is what they want to do.cliftyhanger wrote: ↑Thu Apr 11, 2019 10:46 amDo you really expect a garage to keep a log of "unofficial" inspections? And what standard are they working to? You can keep the receipt with what it is for, but I doubt the person who did the inspection would want to appear as a defence witness. If you want an MoT test, get it done properly. then it is logged on the DVLA computer with no question of its validity.
You must be psychic Justin!TrustNo1 wrote: ↑Mon Apr 15, 2019 8:26 pm My main concern over those that think it doesn't need an MOT is firstly the brake efficiency, you can to a certain extent check balance by braking hard but the roller test is far more accurate than someone who doesn't want to damage their tyres by braking too hard and the other thing is corrosion, the majority of owners won't climb under the car and check the structural parts and brake pipe and mounting points properly. a tap with your fingers isn't a good testing method.
To find a good tester you need to look a bit harder than your local fast fit centre, an older back street garage will likely know an independent experienced tester.
glad you didn't have to find out doing an emergency stopCarledo wrote: ↑Tue Apr 16, 2019 1:01 amYou must be psychic Justin!TrustNo1 wrote: ↑Mon Apr 15, 2019 8:26 pm My main concern over those that think it doesn't need an MOT is firstly the brake efficiency, you can to a certain extent check balance by braking hard but the roller test is far more accurate than someone who doesn't want to damage their tyres by braking too hard and the other thing is corrosion, the majority of owners won't climb under the car and check the structural parts and brake pipe and mounting points properly. a tap with your fingers isn't a good testing method.
To my eternal shame, I took the Carledo for MOT this morning and came home with a FAIL! The first in 9 years, but it just goes to show! If I can miss something as basic as a seized wheel cylinder, anyone can! There were NO symptoms apart from slightly excessive handbrake travel, which i'd put down to the self adjusters needing a tweak, No brake pull or tendency to spin out, no loss of fluid, nothing! So I had no reason to suspect anything was amiss. Last weekend I had it on the ramp to replace the intermediate and lower column coupling (partially seized UJ and knackered bushes respectively) I've used a U/Jd lower coupling this time, the one I took off was NOT a cheap modern copy but the 1973 original. fair enough wear for that length of time. But available replacements are so naff, I went for the UJ! Had I not had quite so big a fight getting the column off, I might have had time to go into the rear drums to adjust and found it........Or not!
Dammit! Scanned the fail to post but can't find it through postimage though it's there on the desktop!
What it said is:-
Service brake has no recorded effort at a wheel, Offside Rear (this under dangerous)
Parking brake efficiency below requirement
Brake imbalance across an axle, Rear
Parking brake inoperative on one side, Offside (these 3 as major, fix asap)
Needless to say, I DID drive it home and I will look into it tomorrow, I have shoes and cylinders in stock.
I'll probably also take this opportunity to do my rear pipe upgrade.
But this is a perfect example of just WHY all cars need to be MOT'd and being old and not used much is NOT a good reason to stop doing it!
Thats the funny thing, it stopped square! On the way home I deliberately tested it on a suitably empty piece of road, gave it a good hard stomp and it STILL pulled up straight. Maybe because of the TJs in conjunction with the rear pressure limiter I used in lieu of the Sprint LSV and couldn't be bothered to remove when I fitted the TJs!
