tamtrucks
#241 Post by tamtrucks »
paint paint n paint...near the end of dong the sill,painting and touching in now
tamtrucks
#242 Post by tamtrucks »
well,this morning got in brown brum and smelt petrol,,,,tank gone again....minutes later tank is out and hole in the bottom roughly 2mm in size....buggar :(
tamtrucks
#244 Post by tamtrucks »
:shock:
well anyway,,,,it turn into a big plate that need to weld in,,,chop the bad section out,150mm x 100mm patch plate now welded in
now i have a problem with the outlet threads,,during welding process the brass fitting has gone moody,looks like threads are shot
has anyone got one spare?
tamtrucks
#245 Post by tamtrucks »
got sick and tried of repairing the tank,,bought a alloy 10gallon tank which fits in a cradle which i made,all good now just waiting for fuel gauge to arrive,,new tank has 0-90ohm sender
tamtrucks
#246 Post by tamtrucks »
waiting to go on. monroe radialmatic fronts with -1" springs and monroe gas-matics rears with -1" springs,was set to fit this afternoon but then a discovery pulled up with no brakes,so suspension swap was put on hold,but fingers crossed this week sometime...thanks to sam for the front springs and thanks to madmart(i think it was you) for the rear springs
yorkshire_spam
#247 Post by yorkshire_spam »
Springs and shocks looking good!
tamtrucks
#248 Post by tamtrucks »
discovery done and gone at last.......dolomite suspension on hold til weather perks up
tamtrucks
#249 Post by tamtrucks »
alternator died yesterday,ign lite came on and didnt go out till put old alternator back on.ign lite now out and battery charging
just took back off and black on all contacts that connect to spinner/brushes,so il clean up later and see if it works
still not fitted the lower`d suspension,but it still look nice and new`ish
tamtrucks
#250 Post by tamtrucks »
just bought browny a present....sprint wheels :D need refurb,all 4 are dated 79...so looking out for a set of sprint wheels nuts 3/8 size
tamtrucks
#251 Post by tamtrucks »
that yearly thing has come again....MOT passed today :bluewave: another year of brum-brum :D
yorkshire_spam
#252 Post by yorkshire_spam »
Good result! Another year's happy motoring.
tamtrucks
#253 Post by tamtrucks »
just a new bosch alternator for browny just need to make engine fixing bracket.the bosch is 55amp
the old one had outer winding damage...burnt wiring and massive short,,so scrapt it! dead 65amp....lasted 2.5yrs`ish
tamtrucks
#254 Post by tamtrucks »
bit more to be done...rear drivers side boot area and rear lower arch
may need bit of donor material....can anyone help? lower arch rear
oily66
#255 Post by oily66 »
Club does a repair panel for the boot floor edge.
Trevor
2017 Jaguar XE R-sport
