Size for 1850 belt with no fan
I've trawled the archive with no result. Although fitting an electric fan is covered nobody seems to have mentioned the size of belt needed if the fan on the 1850 is removed and only the alternator needs to be driven. Can someone give me an idea?
- TDC Cheshire Area Organiser
Re: Size for 1850 belt with no fan
Hi Mike, Unipart no GVB10735. Mine has no fan and that is what's fitted
https://www.ebay.co.uk/itm/V-belt-GVB10 ... Swi0xaIEBB
NOW A CLUB MEMBER 2017057
Thanks Tony. So that's 735 mm long, about what I guessed. Excellent. I have got a puller fan from a Subaru that my son is scrapping and I reckon it can be made to fit behind the Dolly's rad. What shall I do with all the extra BHP I will get if I remove the engine propellor?
Bumpa wrote: ↑Tue Jul 23, 2019 3:22 pm Thanks Tony. So that's 735 mm long, about what I guessed. Excellent. I have got a puller fan from a Subaru that my son is scrapping and I reckon it can be made to fit behind the Dolly's rad. What shall I do with all the extra BHP I will get if I remove the engine propellor?
Donuts in a Dolly. Now that would be worth seeing!
I think he means a boot full from the supermarket
I use a 750mm by 10mm belt, loads of them on Ebay and very cheap.
Russ Cooper
Dursley
UK
Dursley
UK
