Hi All
Is the only way to adjust the idle speed on Weber 45’s to adjust the idle mixture screws? Tickover at the moment is around 1100 rpm. I would ideally like to get it a bit lower.
Any advice would be most grateful
Nigel
Weber DCOE 45’s idle speed adjustment
Triumph Dolomite Club Spares Officer
Track day Sprint for track fun....
Looking for something interesting for summer time daily use...
Skoda Superb 4x4 for everyday use...
Re: Weber DCOE 45’s idle speed adjustment
The idle mixture screws are for setting the idle and lower revs mixture. The idle revs are adjusted by the throttlevalve screws like SU's.
Thanks Jeroen
After a bit more investigation looks like the return springs are not returning the throttle linkage to the correct position and holding the revs up.
New springs ordered
Nigel
New springs ordered
Nigel
Make sure its the springs and not something else stopping them closing properly. Like a butterfly moved etc
Russ Cooper
Dursley
UK
Dursley
UK
Thanks all for the advice..after a bit of tweaking idle speed spot on...
Completed a track day and the car went very well.....
