Splitting a Sprint steering column
PaulB
#1 Post by PaulB »
The lower bearing on my steering column has had its last days. This bearing is the same as Stag and 2000/2500 so unlike the top bearing it is available.
To replace it appears that the lower sliding section of the column needs to be removed. But mine will not come out.
Does anyone know how this lower bearing is replaced?
Thanks,
new to this
Re: Splitting a Sprint steering column
#2 Post by new to this »
There is a drift pin to knock out,have you done that
PaulB
#3 Post by PaulB »
new to this wrote: Sat Nov 02, 2019 4:29 pm There is a drift pin to knock out,have you done that
I haven't found a drift pin, where is it?
PaulB
#4 Post by PaulB »
come on guys someone must know how to do this!
Richard the old one
#5 Post by Richard the old one »
Have you removed the steering column from the car?
Richard the old one
#6 Post by Richard the old one »
I suggest you get a copy of the Haynes dolomite workshop manual but the following is should enable you to do the work.
Steering columb – Dismantling, overhaul and reassembly
Remove the steering wheel and hub from the steering columb and then remove the steering columb from the car.
Then before you go any further I recommend that you check that the spire washer is in contact with the lower bearing until all the end float of the column is eliminated as it may have moved and be the cause of your problem.
Remove the nacelle so that the switch clusters can be removed and the direction indicator trip cam.
Take off the circlip and washer which retains the steering mast upper bearing and carefully slide the upper columb downwards from the housing.
If the upper ball-race shows any signs of rough running or excessive play it can be prised out of the housing. If all is satisfactory it should be greased with a multi purpose grease.
If the lower bearing is to be replaced the column remove the thrust washer if it has not already been removed / fallen off, on later build steering columbs this may have been spot welding in place and the weld will need to be filed / ground off so that the spire washer and tapered nut can be removed.
When refitting the column, first grease and fit the new lower bearing followed by the spire washer which should be fitted loosely at first.
Next tighten the tapered nut fully ensuring that backlash is eliminated but that axial movement is freely obtainable.
Slide the column upwards into the housing, making sure that the upper bearing is correctly positioned. Fit the retaining washer and circlip at the upper end of the shaft.
Carefully press the lower bearing into the housing fully and evenly, ensure that the upper bearing does not move.
Move the spire washer into contact with the lower bearing until all the end float of the column is eliminated.
Finally remember to fit the thrust washer when fitting the column back in the car. I do not see the need to spot weld it.
PaulB
#7 Post by PaulB »
Richard the old one wrote: Mon Nov 11, 2019 9:42 pm
The column is removed from the car and completely stripped down with the inner mast having been removed.
Thank you Richard, its the lower bearing which has disintegrated and which I am trying to replace.
Your explanation is helpful and it is pretty much the conclusion I had come to on how to do it.
