Hi does anyone know the size of the bore the camshaft sits in? Cam measures 1.247" so I assumed the bore would be 1.250" to give clearance but mine seem a bit tighter. Im working on sorting out a reamer to clean up the head and caps.
Sprint camshaft bore?
Re: Sprint camshaft bore?
You mean something like this?
- Ruimer.png (717.62 KiB) Viewed 680 times
I wish
Do you know the bore size? I did look at Hans page and when honed he said it was 0.03mm clearance. (0.0011") Would that clearance be standard or is Hans running them a bit tighter?
I tought i'd pmd you...
Just checked, yes I did.
Yes thank you it never notified me for some reason
. I will mail as suggested
