Sprint sun visor restoration
GrahamFountain
#1 Post by GrahamFountain »
I've got a driver's side sun visor on the Sprint, one of the rarer all white (ish) ones, that's lost all its padding. I don't know what's happened, the passenger side one is fine. But the foam inside the driver's side has turned to what looks like dried-out compost. The vinyl and frame are both fine. Just it's floppy and was filled with dust.
So, I guess I could slit the cover, fill it with some foam-rubber cut to size, and hope to weld/glue the cover back together. But I'd like to see if there's an alternative. Has anybody any ideas for something I can inject into the cover, maybe with that between two boards to keep shape? I think it want's to be something not too heavy and not too firm.
veloce_rosso
Re: Sprint sun visor restoration
#2 Post by veloce_rosso »
GrahamFountain wrote: Thu Apr 30, 2020 12:21 pm I've got a driver's side sun visor on the Sprint, one of the rarer all white (ish) ones, that's lost all its padding. I don't know what's happened, the passenger side one is fine. But the foam inside the driver's side has turned to what looks like dried-out compost. The vinyl and frame are both fine. Just it's floppy and was filled with dust.
Not sure how effective those kits are. The only thing I can think of is find a local upholsterer (man in a shed type set up) and see if he can refurbish them. If you can I seriously look at getting the other visor done as that will likely to degrade at some point, but I suppose this depends on how much your budget will stretch to.
Sorry, can't think of any alternative.
Best wishes, Richard
Awaiting Repair
#3 Post by Awaiting Repair »
GrahamFountain wrote: Thu Apr 30, 2020 12:21 pm .........Has anybody any ideas for something I can inject into the cover, maybe with that between two boards to keep shape?......
The common 'builders' expanding foam may work?
https://www.screwfix.com/p/no-nonsense- ... 50ml/75470
.......but I wonder if there are different grades that might resist snapping, the fire grade stuff for instance? I guess the best thing to do would be to source a less valuable black and white visor and experiment on that first?
Keith
new to this
#4 Post by new to this »
Awaiting Repair wrote: Thu Apr 30, 2020 8:56 pm
Keith
Not sure expanding foam would be the right thing,to uncontrollable until set
may be try the green fibre board,you put under wood flooring for sound proofing,but wrap it in scrim foam first,then you should be able to refit/slide it inside the sun visor
GrahamFountain
#5 Post by GrahamFountain »
I've been looking on eBay, and this looks a possibility: https://www.ebay.co.uk/itm/Medium-Soft- ... 1438.l2649 There's a vid on youtube showing it or something like being moulded.
Problem is, by the time I've bought this stuff and a gun to inject it and put together a frame with two boards to make it stay flat, it all seems a bit much.
