Threaded plug in engine block
KWM338R
#1 Post by KWM338R »
I'm stripping my block down for a thorough clean and repaint and have unearthed a threaded plug I've never seen before as it was covered in gunk.
Is this just simply threaded into the block or If I try to remove it am I going to open a can of worms? I had a major big end bearing failure so need to get at all the oil passageways to make sure all debris is gone.
Regards,
trackerjack
Re: Threaded plug in engine block
#2 Post by trackerjack »
Suggest you leave it well alone as I believe this is the plugged hole for the oilway that is fed by the jackshaft and transfers oil to the head. :D
#3 Post by soe8m »
Yes you can unscrew these. Theres also one around the dizzy. When unscrewing these you can clean all oilway's in the engine and a lot of residu is alway's present in that particular bore. I use a hex plug to close these again.
KWM338R
#4 Post by KWM338R »
thanks Gents.
I'll have to look more closely round the dizzy, I hadn't noticed that one.
#5 Post by Mad Mart »
I've always left them alone. :D
KWM338R
#6 Post by KWM338R »
I don't want to take any chances after finding a big end bearing looking like this.
