So I haven't posted for a short while. All of the last rantings were in relation to the mystery noises and consequently how it is the oil pump could be vibrating against the rack mount when everything else looked ok and more or less measured the same as others cars.
There never was an answer to that but I did work my way through new anti roll bar fittings, replacement drag struts, flipping the engine mounts over, re-setting the height of the gearbox Volvo mount and using the stabiliser bar to provide a bit of "pull"
In doing all of this it came to light that one of rack U bolts had a stripped thread. Second most recent Christine (aka Stephen King) moment where the whole thing was back together but yet again the car found something new to save it the bother of having to exert itself back on the road. Just a couple of days ago I finished putting everything back together including some custom-fitted Sprintspeed rack mounts (custom fitted because of course on my car the welds at the edge of the rack vertical plates were more pronounced preventing simple assembly). For once the steering couplings did seem to align nicely and it all went back together ok before being dropped back on all 4 tyres for the first time in a few months. And a satisfactory gap between mounts and oil pump as well
Of course just lulled into false security. I started the car today, really looking forward to a road trip without the hideous pump-rack vibration, and the next and most recent Christine moment - a weeping water pump. It was of course all fine the last time it ran. Ten-nil to the car ..... more time resting in the garage.
So my water pump and related questions :
1) weeping from that slot underneath the pump means the water pump seals are dodgy? I read more than one comment that after a bit of non-use they might weep but then re-seal. Is that really true? Should I just drive it a bit to see what happens? How long might it take for the re-seal to be apparent?
2) I basically don't buy the above at all. So on the flip side how much risk is there in driving the car with a weeping seal? Could it quickly turn to a gushing seal? I wanted to use it at a wedding in a couple of months but I can't afford the risk of a breakdown
3) leaking through this slot is just a seal issue right? how hard is this job? I notice new improved spec whole pump from Rimmers are 225 ex VAT. Ouch.Can't help thinking while its apart it might be worth replacing whole thing but.....
4) .... at the same time what is the position re the electric water pump option? It can't be much more expensive. How easy/difficult is it to fit? Where can I source the parts ? (ideally a whole kit containing all necessary parts to blank off old pump and fit and plumb in new.
5) very concerned about being able to remove old pump for seals or complete replacement anyway
6) top hose to expansion tank : how hard is this to pres together; mine seems pretty rigid
7) ages since I did much with the cooling system so have forgotten : when refilling do you go to near top of domed thermostat top filler housing or is some space to be left
No evidence of any other issues. Car warms to normal temp and heater works. Has large % of antifreeze permanently - not sure what % - although a while since it was replaced
Really welcome any advice. Time is getting very tight re wedding esp if parts are coming from the UK
thks
