I have removed all of the underseal and drilled out the spot welds, I wont use the whole panel, just the bits I need.
The wheelarch and rear wing have gone as well so I'll remove everything and work from the inside out to repair.
I just cut off what I needed and offered it up ready to weld into place.
Then seam welded along the join. Once ground back you wont see this.
