lower ball joint nut
Re: lower ball joint nut
#1 Post by Carledo »
gaz wrote: Wed Jul 22, 2020 12:30 pm Hi
Can anyone tell me what size nut is used on lower ball joint ,have tried a 7/16 but getting very hard to tighten up.
If you mean the nut on the taper, I doubt it's 7/16" I think the originals were 11/16" (across flats) but i've seen 5/8", 9/16" and even one 17mm nut on aftermarket balljoints! IIRC the thread is a 3/8" UNF but it might be 7/16" UNF.
HTH, Steve
