Radius arm bushes
Dave1942
Radius arm bushes
#1 Post by Dave1942 »
Is it enough to raise and to support the rear axle when changing the bushes?
Richard the old one
Re: Radius arm bushes
#2 Post by Richard the old one »
The official workshop manual states "Raise the car on the jack and support the body on stands."
Dave1942
#3 Post by Dave1942 »
I was hoping to keep weight off the bodywork
jikovron
#4 Post by jikovron »
If the sills are iffy, lift it via an 18inch long piece of 6x2 to spread the load and allow for a stand to go in next to the jack.
Once the axle is hanging then support the axle with the jack under the diff before taking off the arms.
Richard the old one
#5 Post by Richard the old one »
I have cut two lengths of wood, one for each side that I place along the flat part of the sills to spread the load. You can just see in the photo how I did it when I had to replace the trailing arm.
#6 Post by Carledo »
Letting the axle hang greatly improves access to the inner upper bush nuts. I then do one side at a time, it makes controlling the axle a lot easier! Especially as i'm usually alone under there!
Dave1942
#7 Post by Dave1942 »
Thanks for the tips all
