Is it possible that a HGF could put pressure in cooling system to force pump leak? My niggles with engine have shown water pump leak when revs get to 3500 to 4000 an upwards. When revving, it became apparent coolant weeping from 4 piston rear and at exhaust side. Low revs and no obvious sign of leak. I’ve pulled head off and found it pretty grimy after only 1000 miles since being built. Curious if the above and images should give me some additional concern or not. Will get head looked at for warp etc. fingers crossed it was simply a gasket that failed and put it all back together
