1500 Throttle Cable
TurningSpanners
1500 Throttle Cable
#1 Post by TurningSpanners »
Good evening all,
Just wondering if anyone has purchased a new 1500 Throttle Cable recently & was it OK ?
Silly me butchered the one on the car to fit an SK Carb :oops:
I've put the twin SU's back on her (it's a 1300) so needed to get a new cable & I've just received a new one from Rimmer's but either the cable is about 2cm too short or the outer shieth is too long.
I was just going to take some off of the outer shieth so it sits a little closer in the bracket but where the cable seems shorter there's not enough length to safely cut it without damaging the cable.
Just wondering if anyone has a genuine one available to buy ?
Thank you,
Wayne Lee
cleverusername
Re: 1500 Throttle Cable
#2 Post by cleverusername »
My advice is to contact Rimmers before modifying anything, More than likely they have sold you a duff part.
new to this
#3 Post by new to this »
Is your outer case still ok,i replaced my throttle cable using a bike brake cable,
TurningSpanners
#4 Post by TurningSpanners »
Thanks for the replies,
I'll contact Rimmer's to see if they have any issues and hopefully get a replacement.
If that's the same I may have to do the brake cable mod.
Pretty sure I've put the linkages back together correctly as it revs freely operating it manually.
Wayne Lee
TrustNo1
#5 Post by TrustNo1 »
you can buy the cable from place like carbuildersolutions much cheaper
TurningSpanners
#6 Post by TurningSpanners »
Just a final update on this one
Rimmers sent me a TCE412, which by all accounts was the same as the UKC1329 - as above, it didn't fit so I found a NOS UKC1329 which fitted perfectly.
Rimmers in all fairness have supplied a Return Number quickly so it has gone back today.
No just the small matter of setting the carbs up again... :roll:
Wayne Lee
TrustNo1
#7 Post by TrustNo1 »
TurningSpanners wrote: Fri Nov 06, 2020 10:46 am Just a final update on this one
You can always give me a shout if you get stuck for parts as I keep a lot of 1300/1500 (both FWD and Dolly) parts in my workshop.
TurningSpanners
#8 Post by TurningSpanners »
Thank you,
That's good (& handy !) know,
Wayne Lee
