Smiths Guage - green filter
payload
#1 Post by payload »
Hi All,
Does anybody know of a source for the green bulb filter within the Smiths dashboard guages, specifically the voltmeter and tachometer. I have hunted but I just can't find them as a separate part.
Ian
dollyman
Re: Smiths Guage - green filter
#2 Post by dollyman »
Hi Ian, you can get led bulbs with the green filter and they look very smart.
payload
#3 Post by payload »
Thanks Tony, my natural instinct is to keep it original as much as I can, but if I can't source the green filters then green LEDs are probably the best answer. I guess LEDs draw less current and last longer too.
Ian
dollyman
#4 Post by dollyman »
payload wrote: Tue Dec 15, 2020 10:27 am Thanks Tony, my natural instinct is to keep it original as much as I can, but if I can't source the green filters then green LEDs are probably the best answer. I guess LEDs draw less current and last longer too.
Ian
I agree with keeping it original Ian, but if you drive a fair amount at night? You will be amazed at the difference, and just keep the old bulbs to put it back to standard as no other mods are needed.
payload
#5 Post by payload »
you've sold it to me Tony!
I will order some from https://www.classiccarleds.co.uk/, they seem to have everything I would need to cover dash bulb wise
dollyman
#6 Post by dollyman »
payload wrote: Tue Dec 15, 2020 11:12 am you've sold it to me Tony!
They are who i would recommend Ian :thumbsup: Let us all know what you think :D
TFN
#7 Post by TFN »
Good morning, I colour clear bulbs with a green Sharpie pen. You need to go over them a few times to get the depth of colour but they look great once done.
payload
#8 Post by payload »
Cheers for the 'felt' tip TFN !
I've ordered the LEDs already but will hold that method in reserve
Ian
TFN
#9 Post by TFN »
Always good to have a plan 'B'! Please post a picture when you've fitted them, it'd be good to know how they compare to the originals. The volts gauge in the picture below is the bulb I coloured green - The others are original. Not perfect but near as it needs to be!
GrahamFountain
#10 Post by GrahamFountain »
Just fitted a set of these https://www.ebay.co.uk/itm/10-x-E10-Min ... 2749.l2649 in the dash.
This pic shows a bit of a mixture: The speedo still has the green filter intact, but the volt meter and temperature gauge haven't. All three have these green LEDs in. The clock still has it's green filter and is fitted with a white LED. It was brighter than the speedo when that had a white LED, but not so noticeably a different colour. But its a different bulb type of course, and it's brighter than I really want.
The dash lights don't look quite so blue in the flesh. But they still look bluer than the clock.
So I think I shall look for a green LED to go in the clock to see if that then matches the rest of the dash better.
payload
#11 Post by payload »
Fitted the LED replacement bulbs yesterday, here's a pic as promised.
The image makes them look brighter than they actually are, but they are definitely a big improvement on the stock set up.
Thanks all for the advice.
Ian
GrahamFountain
#12 Post by GrahamFountain »
I got the green LED for the clock and swapped that for the white one that was a bit bright, but it's worse if anything. Both are the wide angle COB type LEDs. But I've ordered a couple of white through hole LED type bulbs to try and fix the rear demister switch light. They tend to be more directional, like the middle bulb in the boot light thread. So, maybe they'll appear less bright than the COB type.
Failing that, I suppose I'll have to drop the supply current to the LED with an additional series resistor. I thought about a different colour LED to be dimmed by the green filter in the clock, but I don't see that will work, as they tend to be a bit narrow band. S'pose a yellow LED, which has a red and a green LED in parallel, might be dimmer in the green alone.
It's a good job I've modified a spare glovebox inner to come out with the glovebox door and stay in place. Getting at the clock would be a right pain else.
GrahamFountain
#13 Post by GrahamFountain »
Here's a pic showing the over bright clock - taken with the 2/3" CCD X-S1 this time, not the phone camera.
