Early Sprint Chassis Plate?
- GrahamFountain
Re: Early Sprint Chassis Plate?
I've found the part number UKC7820 for the BLMC commission plate.
Has anybody got any info on the date range and applicability for that part number?
- GrahamFountain
That disproves the theory that the change was aligned with the company name change in mid 1975 at least.
- maitretjak
I don't really understand why this is so important to some but here is a photo of the plate off VA 1254 DL. The photo has been cropped out of a photo which I took of the engine bay while it was sitting looking very neglected in an open field. The car was too rough around the edges for me to consider restoring.
- 20070511-0007Ptr McC Sprint plate.jpg (102.35 KiB) Viewed 1026 times
- GrahamFountain
Because the BLMC ones are a tenner cheaper?Robert 352 wrote: ↑Thu Dec 17, 2020 7:28 pm I don't really understand why this is so important to some
I don't think it is that important. But the weather's too crap to go out and do stuff, the pubs are all shut, and I'm bored of AoEII.
- Len Hughes
Hi Graham,
Sorry I'm a bit late to respond on this.
The one in your original post is an exact replica of the one on my early 73 car VA369.
Len
Len
1973 Mimosa Sprint
1973 Magenta TR6
1973 Magenta TR6
They changed vey late in production when the VIN numbers changed to the then newer style 13 digit I believe.
- GrahamFountain
I've come to the conclusion that the early Sprints did have the British Leyland UK Ltd plates, and its not restorations using a later, similar plate.Len Hughes wrote: ↑Fri Jan 01, 2021 10:52 pm Hi Graham,
Len
However I still don't understand why that's so with the 1972-3 1850s having the BLMC plate and the company name not changing from BLMC to BL UK till 1975 after Sir Don Ryder's National Enterprise Board took majority ownership for HMG - intending to spend just under £3 billion (allowing for expected inflation) doing it up and ending up spending more like £12 billion by 1980.
The BMM are supposed to be getting back to me on their understanding of all this in the new year. If anything meaningful comes of that, I'll pass it on.
