I’ve recently bought a new pair of front stub axles for my Dolomite, SprintSpeeds Ford pattern pair to be precise.
So I’ve had to remove the old ones, looked in the workshop manual and it says to loosen the nut in the back and press out. easy enough, had my local garage press them out, didn’t half fire out of the upright
Now that I’m at this stage, does anyone know what torque that nut is meant to be at? The manual just says to tighten it, unless I’ve missed a section somewhere. Am I just meant to tighten till I can’t anymore?
Anybody have any experience?
Edit:
Never mind, just reread the workshop manual and there’s a torque wrench setting page I entirely missed. Looks to be 80lbft of torque. I’ll leave this up for anyone else’s information
Stub Axle Replacement
- 669A36BF-D6C8-4ABA-9138-4419A0A147F5.jpeg (106.52 KiB) Viewed 481 times
Re: Stub Axle Replacement
80? That's about two groans and a fart by my calculations.
Have you bought the alli front hubs as well as the stub axle ? what wheels are you fittingBoost All The Dollys wrote: ↑Thu Mar 11, 2021 9:37 am I’ve recently bought a new pair of front stub axles for my Dolomite, SprintSpeeds Ford pattern pair to be precise.
Edit:
I did think 80 was a little low but then again, it’s just to lock in the taper and that’ll do must the heavy lifting
Yeah, I’ve cheaped out on the new Alloy hubs and bought some second hand iron ones. I’ll probably upgrade to the alloy ones eventually but couldn’t afford them as of this moment, for everything it was around £250 for all the bits but old iron ones were around £90new to this wrote: ↑Thu Mar 11, 2021 12:36 pmHave you bought the alli front hubs as well as the stub axle ? what wheels are you fittingBoost All The Dollys wrote: ↑Thu Mar 11, 2021 9:37 am I’ve recently bought a new pair of front stub axles for my Dolomite, SprintSpeeds Ford pattern pair to be precise.
Edit:
