That's topical, Richard. We received this from Chris Witor a few days ago;
I am in a position to get the steel cup washers re made that are welded to where the upper axle link bushes fit.
Apparently they are prone to rust?
They would be £20 + vat for a set of 4.
Maybe you could gauge interest though the forum, and the magazine. If there is enough interest via emails to me, I will get them made.
Chris
Are you enjoying using our forum? If so why not support the owners club which provides it by joining The Triumph Dolomite Club? Help us to preserve these great cars for future generations. Club membership costs just £30 for one year or £55 for two years. See https://forum.triumphdolomite.co.uk/vie ... =4&t=37824 for details.
I do not recognize the part that Chris is considering to remanufacture we or I would need the part number or a photograph to be able identify it.
He can already supply the subframe lower cupped washer that I had to replace if you look at his advert in Dolly Mixture. His are manufactured in stainless steel. Part number 138626SS
Luckily I had a couple spare from a car that I scrapped a couple of years ago.
The subframe cup washers failing is (was?) a common problem.
Early Dolomites, Toledos and 1500s had cup washers at the front as well as the back
(fortunately the Sprint type bushes can be fitted instead).
When a subframe drops it is held only by the steering intermediate shaft!
The message from Chris is about the mounting brackets on back axles.
Ian
TDC Forum moderator PLEASE help us to maintain a friendly forum,
I was aware that it is a common problem that the cup washers rust away but it did not realize that there was a difference between the early and late arrangement. All my Dolomites have been 1977 or later.
I did suspect that it might be the rear axle bits that Chris is considering for remanufacture. I always give the area a good spray with waxoil regularly.
sprint95m wrote: ↑Tue Mar 23, 2021 1:14 pm
Back when I was using my old 1850HL as daily transport it was sent to my local garage several times as the steering was so heavy as to be almost unusable and they could never get to the bottom of it. A couple of years later I got underneath and realised that it was because the subframe was falling off!
1976 Triumph Dolomite 1850HL"Trevor, the Tenaciously Terrible Triumph" - Rotten as a pear and dissolving into a field in rural Aberdeenshire. 1977 Triumph Dolomite 1300"Daisy, the Dilapidated Dolomite of Disaster" - Major resto, planned for completion 2021. 1983 Triumph Acclaim L"Angus, the Arguably Adequate Acclaim - On the road as a daily driver.
