I need 2 tyres for BUD, which is sat on Sprint alloys.
Has anyone any expereience of 185/70 x 13 on the back?
I'm just thinking that a bit of width, and a bit more sidewall may help the gearing a touch more.
If not, I'll stick with 175/70
Answers on a forum please!
BWJ (Incredibly happy)
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018 NOBODYexpects the Canley Inquisition!
Don't go large if your rear bushes are getting elderly. Blue had 185/70 on the back when I got it, they rubbed on bumps, hard cornering and very badly with rear passengers. The rubbers weren't great but I wouldn't have called them knackered either. I've not retried it since rebushing and other on here have had better luck than me.
From memory 185/60 is a closer match in the rolling circumference so will affect the speedo less.
1300dolly wrote:width will not make any difference to gearing. just a bit more rubber on the road. go with the skinny steels, great fun at this time of year.
Well, the width will make a difference to the gearing as it can influence the sidewall depth depending upon the code of the tyre.
e.g.
165/80 R13 is 165mm wide and 80% of that is 132mm
185/80 R13 is 185mm wide and 80% of that is 148mm
Which means the rolling circumference of the 185/80 is greater.
1980 Dolomite Sprint with a touch of BLTS Balanced Lightened and Tweaked 13B Rotary and SsuperCharged.
Back in my possession 22 September 2019. Rebuilding the Sprint time taken so far, 111Hrs@15/12/2020
212Hrs @31/12/2021 352 @ 28/11/2022 455Hrs @ 20/10/2023 565Hrs @ 07/12/2024
Member TDC no 0471
I do have some 185/70s here, but they are on non-Sprint alloys with a different offset, so no good for a quick check. However, you're welcome to have the tyres for the price of removing them from the wheels if you want to take them away and try them on some sprint wheels.
I used to run 185 70s on my 1850 on sprint rims.
They rubbed ocasionally on the inside due to worn bushes but were fine once it was polly bushed.
The sprints tend to rub on the outer lip due to having the wider rear axle.
