Gearbox flange nut removal
IncaDolly78
#1 Post by IncaDolly78 »
Hi all
I want to remove the driveshaft flange nut on my gearbox (Sprint), how do other people do this? Officially it requires an RG421 tool but I guess these no longer exist, do most people fabricate something instead? I tried securing two bolts on to the gearbox flange and locking with a crowbar and attempting to undo the bolt with a socket and extension bar but I stopped as it didn't feel overly safe! Thanks for any advice :-D
Re: Gearbox flange nut removal
#2 Post by Carledo »
Put it in gear and use a rattle gun, that's my preferred method!
Hmmm.......
#3 Post by sprint95m »
:D Not possessing a rattle gun or any type of gun for that matter,
I bolt a length of channel to the flange (as this is safer than the prybar wedged in place option)
Ian
IncaDolly78
#4 Post by IncaDolly78 »
Thanks to you both, looking at the leaking diff seal I will need to do the same there too! :roll:
#5 Post by Mad Mart »
I got a piece of 40x5 flat bar. Drilled two holes and notched out a bit to allow the socket to pass. If the axle is still in situ then let the bar rest against the floor.
