Evening all,
Im in need of sourcing a Master & Slave repair kit for my 75 Toledo and wondered if a Dolomite 1300 kit would work as having trouble finding Toledo specific ones.
Toledo Master & slave cylinder repair kits
Re: Toledo Master & slave cylinder repair kits
Should do, just check the bores, as it in possible they have been changed. And assume you have a servo on the toledo?
Bore size is cast or stamped on the side of the cylinder. Clutch should be 5/8 or 0.625 (same thing) Brake Master if servo is 0.75 I think? But do check.
