Towing weight?
SprintV8
Re: Towing weight?
#16 Post by SprintV8 »
If the vehicle is on Sorn no MOT or unroadworthy
Vehicle must be put on either a Flat Bed or Trailer.
Any part of a vehicle with its wheels on the road must be Taxed and MOT (If Applicable).
Dragging it behind on a Harvey Frost or even a Spec lift is now a no no.
Ask me how I know. 😡
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
harvey
Re: Towing weight?
#17 Post by harvey »
^^^^ Dolly wheels will get you round the "wheels on the road" but then the truck towing it can't be taxed in the "Recovery Vehicle" class, it has to be taxed PLG or Goods. I did towing for years and the longer I went on the worse it got. Now I'm glad to be out of it.
naskeet
Re: Triumph Toledo Towing weight?
#18 Post by naskeet »
naskeet wrote: Fri Jul 02, 2021 7:13 pm The Triumph Toledo’s Towing Capacity & Limitations!?!
According to the Towing Information sub-section on Page 04-3, of Section 04 – General Specification Data, of the official loose-leaf BLMC Triumph Toledo 1300 & 1500 Repair Operation Manual [Part No. 545168, Issue 3], the towing limits for the Triumph Toledo 1300, 1500 & 1500TC saloons are as follows:
Maximum braked-trailer weight: 15 cwt (i.e. 762¼ kg by calculation)
Maximum un-braked-trailer weight: 3•94 cwt (i.e. 200 kg), provided the total weight of the car and trailer (i.e. combined weight of the car, car’s payload, trailer & trailer’s payload), does not exceed the car’s maximum gross-vehicle weight for cars with1300 & 1500 single carburettor engines, or 28•8 cwt (i.e. 1465 kg) for cars with 1500 twin-carburettor engines.
For comparison purposes, does anyone have the BLMC Triumph officially sanctioned maximum towing-weights data, as given in the General Specification Data section of the brown-plastic coated, four-ring, loose-leaf folder based, workshop manuals for the Triumph 1500 and Triumph Dolomite 1300, 1500, 1500HL, 1850, 1850HL & Sprints?
Regards.
Nigel A. Skeet
Re: Towing weight?
#19 Post by Carledo »
harvey wrote: Sat Jul 03, 2021 12:45 pm
Carledo wrote: Wed Sep 09, 2020 9:55 pm suspended tow recovery vehicles, (good old Harvey Frost)
Happy days! I've still got my tubular Harvey frost. I just can't bring myself to get rid of it. I had it mounted on an ex-US military Dodge 4x4 crewcab and in its time it was a great piece of kit.
I'm pretty sure the Harvey Frost style of winch, bar and chains is no longer usable for recovery and towing rigs need a "spectacle bar" to comply with current legislation for suspended tow. Which is a shame, I loved the old Harvey Frost, I learned to manoever a SWB Landy with a car on the hook in very tight confines, before I was even old enough to drive. Years later, I bought the same Landy, complete with Harvey Frost and used to moonlight on the M4 with it and a VHF radio that picked up Police frequencies. Happy days, the Landy was a Total POS, which had been cut and shut out of 2 damaged ex military SWB Landies by a man who didn't own a tape measure, the wheelbases were out by better than an inch, side to side! It crabbed a bit!
captain_70s
Re: Towing weight?
#20 Post by captain_70s »
From my '76 brochure. For a 1300, but I suspect the towing limit is mostly based on the fact that the Dolly has very little weight at the rear end and the structure the tow bar mounts to is very insubstantial.
Back in the old days you could pretty much tug along whatever your engine could manage with, but these days you're limited by law to the original recommendation of the car's manufacturer. In the case of the Dolly that puts you into camper tent/tiny 2 berth fibreglass job territory I fear.
naskeet
Re: Towing weight?
#21 Post by naskeet »
captain_70s wrote: Mon Jul 05, 2021 12:31 pm Image
That maximum towing weight of 1680 lbs or 762 kg quoted in your 1976 brochure for the Dolomite 1300 would have been for a BRAKED trailer. What I shall be particularly interested to learn, is what weight limit is given for an UN-BRAKED trailer.
When and if I want to go camping, I shall use the 1973 VW "1600" Type 2 Westfalia Continental motor-caravan in preference to the 1974 Triumph Toledo 1300 "HL Special". Both vehicles will be equipped with towing brackets, but at sometime in the future, I intend to use the Toledo to tow an unbraked ERDE 142 general-purpose & camping trailer, for trips to the local recycling centre, garden centre, builder's merchant and DIY store.
Regards.
Nigel A. Skeet
Robert 352
Re: Towing weight?
#22 Post by Robert 352 »
The towing regulations in this part of the world are clearly quite different to what you have in the UK as is evident in the photo below.
It is legal to a-frame a car here that is both unregistered and without a warrant of fitness – your equivalent of a MOT. When I am towing I do run a cable from the tow car to a “trailer board” sitting in the back window of the car being towed which shows both brakes and indicators.
It is a requirement here that all cars must have a warrant of fitness before they can be registered and driven on the road.
Recently I completed the restoration of the chassis on one of the Dolomite Sprints which I have been working on, on which the registration had lapsed. In order to re-register the car had to be taken to a special testing station where it underwent a very extensive Vehicle Safety Check.
I checked with the Inspectors who gave me two options on delivering the vehicle for checking. Either I delivered the car on a car transporter or I could a-frame the car to them, leaving as I pointed out the a-frame mounting brackets which were bolted to the front bumper.
I chose the latter method, for it was much simpler to do. The inspector spotted my previously restored Sprint HU 5000, the tow car, and was satisfied that the Sprint HU 5089 being returned to the road will finish up in the same condition.
The question of towing weights was never raised.
What I had to do to satisfy the inspectors will be covered in a post on my thread on HU 5089 Dolomite Sprint Restoration shortly.
Robert
20140325-4749Pf Dolomite train.jpg (307.19 KiB) Viewed 1148 times
naskeet
Re: Towing weight?
#23 Post by naskeet »
Robert 352 wrote: Tue Jul 06, 2021 10:09 pm The towing regulations in this part of the world are clearly quite different to what you have in the UK as is evident in the photo below.
Robert
It's debatable whether it was part of the vehicle inspectors' remit to specify towing weights to you, as the vehicle being tested would only come into their jurisdiction once the car had been delivered. I suspect that you would have been better served by contacting the traffic police, to seek advice about what towing restrictions might be applicable to your specific towing vehicle.
https://www.nzta.govt.nz/resources/glov ... owing.html
https://www.nzta.govt.nz/resources/glov ... ml#howmuch
How much can your vehicle tow safely?
« Most vehicles have tow ratings given to them by the manufacturer specifying the gross trailer weight braked, unbraked, or both, that the vehicle can safely tow. Although the law does not require these tow ratings to be followed, the NZ Transport Agency recommends that they be taken into account. »
« In addition to the requirements above, the law requires that every light vehicle and trailer combination must be capable of stopping within a distance of seven metres from a speed of 30km/h. In effect, this means that the maximum allowable weight of an unbraked trailer is limited by the weight and braking ability of the vehicle being used to tow it. »
« The Transport Agency recommends, as a guide, that the laden weight of an unbraked trailer should not exceed three quarters of the unladen weight of the towing vehicle and then only if the towing vehicle's brakes and tyres are in excellent condition. A trailer heavier than this may prevent the vehicle combination from meeting the seven metre from 30km/h brake performance requirement. To illustrate the increase in stopping distance when towing an unbraked trailer, consider a trailer with a laden weight equal to the weight of the towing vehicle. »
« This combination can be expected to have double the stopping distance of the towing vehicle alone, and even a towing vehicle with good brakes is likely to fail the legal brake performance requirement of seven metres from 30km/h. If the trailer is equipped with brakes, it may be possible to safely tow a trailer heavier than three quarters of the unladen weight of the towing vehicle, but the seven metres from 30km/h brake performance requirement still applies. »
Regards.
Nigel A. Skeet
