Camber issues
dololo
Camber issues
#1 Post by dololo »
Hi all ,
i have changed all my 1850 front bushes by polyurethane from superflex , known as one of the best choice for quality .
After 200 kms camber went wrong . i 've added some plate washer behind brackets (two on each side) to get my wheels vertical .
After one rregularity rally ( 500 km including 100 km spécial stages) camber is ruined and tyres look "tired" .
Any idea ?
cliftyhanger
Re: Camber issues
#2 Post by cliftyhanger »
Did you check the toe in? adding shims may have upset that. Indeed, just fitting new bushes could cause that to change.
TrustNo1
Re: Camber issues
#3 Post by TrustNo1 »
without jacking the car up loosen the bolts then retighten.
