1500HL Fuel pump ejecting petrol through small hole
MikeB1500
#1 Post by MikeB1500 »
Although I have owned my 1500HL for some time this is the first time I have posted. Any advice or help would be greatly appreciated.
The car has sat for some time unused after someone broke in smashing the rear door vent glass and ripping off the steering column.
I have now replaced the steering column and will be looking to replace the glass shortly.
I have replaced all of the rubber sections in the fuel lines as they had split and also having replaced the battery the car now starts reasonably well.
My question is with regards to the fuel pump, when the engine is running there are small amounts of petrol being pushed out of the small hole in the side of the fuel pump.
Do I assume that there is a rubber part inside the pump that has split or perished? Is this rubber part replaceable or do I need to replace the complete pump?
dollyman
Re: 1500HL Fuel pump ejecting petrol through small hole
#2 Post by dollyman »
Better replacing the pump i'm afraid. They aren't expensive.
MikeB1500
#3 Post by MikeB1500 »
Thanks Tony for the help & quick reply.
I was aiming to keep as much as original as possible but guess this isn't always going to be possible and in reality doesn't really matter as it will be more about getting the car back on the road and being as reliable (and safe - no fuel escaping) as is possible!
cliftyhanger
#4 Post by cliftyhanger »
Rebuild kits are available, bit of a fiddle to do but doable at home.
New pumps seem to be too high a pressure and require a regulator.
Hope you used proper branded R9 etc fuel hose......especially with E10 now in general use.
BobM
#5 Post by BobM »
You should check your oil level has not risen. If petrol is coming out of this vent, then it is leaking past the diaphragm and can drain to the sump. This will dilute the oil.
The type of pump shown in your photo can not be repaired and needs to be replaced.
Bob
cliftyhanger
#6 Post by cliftyhanger »
BobM wrote: Thu Sep 02, 2021 8:33 am You should check your oil level has not risen. If petrol is coming out of this vent, then it is leaking past the diaphragm and can drain to the sump. This will dilute the oil.
Bob
Looking again you are indeed correct. I saw it was an AC pump, and assumed it could be taken apart, but it appears to be "sealed"
MikeB1500
#7 Post by MikeB1500 »
cliftyhanger wrote: Thu Sep 02, 2021 8:18 am Rebuild kits are available, bit of a fiddle to do but doable at home.
I used R6 fuel hose as image, what is the difference between R6 & R9?
marshman
#8 Post by marshman »
Permeation levels and pressure. R9 has much lower levels of fuel permeation - 15 vs 600ppm and is rated for high pressure fuel injection systems.
As your car, and all unmodified Toledos and Dolomites, have low pressure carburettor fuel systems R6 is OK but R9 is better. The general recommendation these days is to fit good quality R9 hose.
Roger
link to the standard:
http://www.volksbolts.com/faq/SAEJ30.pdf
1971 Stag Auto White
TrustNo1
#9 Post by TrustNo1 »
the pump is foobarred, the diaphragm has split and these are not rebuildable as the lip is pressed not screwed on like the slightly earlier ones, there is one screw on the top but that only accesses the filter.
I should have a used spare one in my box box of ' bits that may be useful one day'
MikeB1500
#10 Post by MikeB1500 »
Thanks everyone for your replies & advice.
I have now replaced the pump and I have also changed the oil.
