Hello all.
Can anyone enlighten me as to what you would expect if the inhibitor switch had failed on an automatic?
A friend has asked me this question as he has an auto Sprint which was running fine until recently. Despite changing points, condenser and various checks it will crank, but not fire.
My response was "is it the inhibitor switch?" however I then wondered if this prevents the cranking also?
Luckily I haven't yet experienced this with my own auto!
Any pointers or advice that I can pass on much appreciated. I'm sure I've read on here somewhere the art of bypassing the switch for fault finding.
MC.
Diagnosis/symptoms of Sprint auto inhibitor switch failure
Matt Cotton
1980 1500HL - OPD
1976 Sprint - SWU
1980 1500HL - OPD
1976 Sprint - SWU
Re: Diagnosis/symptoms of Sprint auto inhibitor switch failure
The inhibitor switch only stops it cranking in R,D,2,1. It should crank in P & N only. If it cranks it won't be the inhibitor switch causing the non-start.
Don't bypass it.
Don't bypass it.
- TDC Cheshire Area Organiser
Does the Sprint have a ballast resistor Matt? Usual culprit.
NOW A CLUB MEMBER 2017057
Thanks gents. Yes I think it does Tony. I will pass the information on.
MC
MC
Matt Cotton
1980 1500HL - OPD
1976 Sprint - SWU
1980 1500HL - OPD
1976 Sprint - SWU
