The following information is based on the 1973 Second edition workshop manual.
I've included scans of the original pages so that the data can be double checked for mistakes.
When I get time I plan on posting:
Lubricants/Fuels/Fluids - capacities.
Torque settings
Colour codes
Technical Data
My intention is to provide forum users with a "quick reference" . Obviously I don't guarantee the accuracy of the information, it is provided as "to the best of my knowledge".
If anyone knows of data/information that supersedes this please let me know.
Last edited by yorkshire_spam on Sun Feb 06, 2022 4:02 pm, edited 1 time in total.
TORQUE WRENCH SETTINGS
DOLOMITE NUT TIGHTENING TORQUES
Operation Description Specified Torque
ENGINE (lbf ft) (kgf m)
Alternator to timing cover 5/16" U.N.C. bolt **20 2.8
Adjusting link to alternator 5/16" U.N.C. setscrew 20 2.8
Bearing caps to block 7/16" U N F bolt 65 8.9
Camshaft bearing cap 5/16" U N F stud 14 2
Camshaft cover attachment 5/16" U.N.F. stud 2 0.28
Carburetter attachment 5/16" U.N.F. stud 14 1.9
Chainwheel to camshaft 1/4" U.N.F. setscrew 10 1.4
Chain wheel to jackshaft 3/8" U.N.F. setscrew 38 5.3
Clutch to flywheel 5/16" U.N.F. setscrew 22 3
Connecting rod 3/8" U.N.F. bolt 46 6.4
Cylinder head to block 7/16" U.N.C. stud nut 55 7.6
Cylinder head to block 7/16-" U.N.C. bolt 55 7.6
Drain plug to sump 3/8" Dryseal plug 25 3.5
Engine to transmission unit 5/16" U.N.F. bolt 20 2.8
Exhaust manifold to cylinder head-inner 3/8" U.N.C. setscrew 34 4.7
Exhaust manifold to cylinder head-outer 3/8" U.N.C. setscrew 22 3
Flywheel to crankshaft 3/8" U.N.F. bolt 45 6.2
Idler shaft keep plate to cylinder block 5/16" U N F C'sk screw 22 3
Inlet manifold attachment 5/16" U N C setscrew 20 2.8
Oil pump to cylinder block 5/16" bolt 20 2.8
Oil sump to cylinder block and timing cover 5/16" U.N.F. 20 2.8
Should maintain a minimum of 8 lbf ft (1.1 kg m) after a settling period.
Plug to cylinder block 3/4" B.S.P. plug 25 3.5
Plug (water transfer housing) 5/8" U.N.F. plug 20 2.8
Pulley to crankshaft 5/8" crankshaft bolt 120 16.6
Sparking plug into cylinder head 14 mm sparking plug 20 2.8
Starter motor attachment 3/8" U.N.F. bolt 34 4.7
Support bracket and chain guides to cylinder block 5/16" U N F setscrew 20 2.8
Timing chain tensioner to cylinder block 1/4" U.N.F. bolt 9 1.2
Timing cover to cylinder block and head 5/16" bolt 20 2.8
Water pump cover to cylinder block 5/16" U.N.F. 20 2.8
Water pump retaining bolt 5/16" U.N.C. bolt 14 1.9
Water transfer housing to cylinder head 5/16" U.N.F. setscrew 20 2.8**
AUTOMATIC TRANSMISSION-continued (lbf ft) (kgf m)
**Governor retaining bolt 18 2.5**
Oil cooler and mounting bracket to radiator mounting 5/16 " U N F setscrew 20 2.8
Oil pan drain plug 3/8" Dryseal 12 1.7
Oil pan to case M.6 7 1.0
Parking brake cam plate to main case M.6 6 0.8
Pressure point on case 1/8" Dryseal 8 1.1
Pump adaptor/front pump housing 6/16" U.N.C. 22 3.0
Pump adaptor to transmission case M.8 25 3.5
Rear engine mounting to cross-member 5/16" U N F setscrew 20 2.8
Rear engine mounting to transmission unit 5/16" U.N.F. setscrew 20 2.8
Rear servo cover M.8 25 3.5
Starter motor attachment 3/8" U N F bolt 34 4.7
Transmission adaptor to transmission 5/16" U.N.F. bolt 20 2.8
Transmission case to converter housing lower M.12 50 6.9
Transmission case to converter housing upper M.10 30 4.1
Tube location plate M.5 2 0.3
REAR AXLE
Brake backplate attachment 5/16" U.N.F. bolt 14 2.0
Crown wheel bolt 3/8" U.N.F. bolt 45 6.2
Hub to axle shaft 5/8" U.N.F. 120 16.6
Hypoid flange to pinion 5/8" U N F 120 16.6
Hypoid housing attachment 5/16" U N F bolt 20 2.8
Hypoid housing bearing-cap retention bolt 3/8" U N F bolt 38 5.1
Plug to rear axle 3/8" N.P.T. plug 25 3.3
Propeller shaft to axle flange 3/8" U.N.F. 34 4.4
Road wheel to hub 3/8" U N F stud 48 6.6
FRONT SUSPENSION
Anti-roll bar to front strut assembly-link 5/16" U.N.F. 14 2.0
Anti-roll bar to front sub-frame 3/8" U.N.F. setscrew 34 4.7
Ball pin to vertical link 1/2" U.N.F. 50 7.0
Calliper to vertical link 7/16" U.N.F. bolt 65 9.0
Damper plate to wishbone 3/8" U.N.F. bolt 34 4.7
Damper to upper wishbone 3/8" U.N.F. bolt 34 4.7
Dust shields to vertical link 7/16" U.N.F. setscrew **65 9.0**
Friction disc to front hub 3/8" U.N.F. bolt 34 4.7
Front sub-frame to body mountings 1/2" U.N.F. bolt 48 6.9
I.F.S. mounting bracket to front sub-frame 3/8" U N F bolt 32 4.4
I.F.S. mounting bracket to front sub-frame 5/16" bolt 20 2.8
**FRONT SUSPENSION—continued (lbf ft) (kgf m)
Lower ball pin to wishbone 7/17" U.N.F. 45 6.2
Lower wishbone to I.F.S. mounting bracket 3/8" U.N.F. bolt 38 5.3
Strut to lower wishbone 7/16" U.N.F. bolt 65 9.0
Strut to sub-frame 7/16" U.N.F. on strut 38 5.2
Stub axle to vertical link 9/16" U.N.F. stub axle 80 11.1
Tie-rod lever and ball joint to vertical link 7/16" U.N.F. special bolt 65 9.0
Upper ball joint and damper plate to upper wishbone 3/8" U.N.F. bolt 34 4.7
Upper wishbone to fulcrum shaft 7/16" U.N.F. on shaft 38 5.1
Upper wishbone to fulcrum shaft 7/16" U.N.F. jam nut 34 4.7
Wheel to hub 3/8" stud 48 5.6
REAR SUSPENSION
Damper assembly to lower link 7/16" U.N.F. bolt 38 5.3
Lower link to body and axle 7/16" U.N.F. bolt 48 6.2
Mounting bracket to body and forward fixing 5/16" U N F setscrew 20 2.8
Rear anti-roll bar 3/8" U N F bolt 34 4.7
Rear damper to body 1/4" U N F setscrew 9 1.2
Upper link to body brackets and axle 7/16" U.N.F. bolt 38 5.3
STEERING
Flexible joint to steering unit and `U' joint shaft 5/16" U N F bolt 14 2.0
Flexible joint coupling bolt 1/4" U N F 9 1.2
Lower support tube to body 5/16" U.N.F. setscrew 20 2.8
Lower support tube to support bracket 1/4" U N F setscrew 9 1.2
Rack and pinion assembly to sub-frame 5/16" U.N.F. `U'-bolt 14 2.0
Steering-column clamp 3/8" U.N.F. stud 20 2.8
Steering-column lock to housing Shear head bolt Tighten to shear
Support bracket to lower fascia rail 1/4" U.N.F. setscrew 9 1.2
Support lower column 1/4" U.N.F. setscrew 9 1.2
Tie-rod ball joint assembly 3/8" U.N.F. on ball end 32 4.4
Universal joint to steering column 5/16" U N F 20 2.8**
**BODY (lbf ft) (kgf m)
Automatic seat belts fixing to BC post 7/16" U.N.F. setscrew 32 4.4
Brake pedal mounting to body 3/8" U.N.F. bolt 34 2.8
Brake pedal support bracket to scuttle 1/4" U N F setscrew 9 1.2
Brake pedal support bracket to scuttle 7/16" U.N.F. setscrew 45 6.2
Clutch pedal to support bracket 3/8" U.N.F. bolt 32 4.4
Clutch pedal mounting 5/16" U.N.F. setscrew 20 2.8
Drain tap to radiator Drain tap 14 2.0
Fuel tank drain plug 5/8" U.N.F. 38 5.1
Safety harness to bracket tunnel 7/16" U.N.F. bolt 32 4.4
Seat belt tunnel bracket 7/16" U.N.F. bolt 32 4.4
Seat slides to floor 5/16" U N F setscrew 14 2.0
Steering lock to column Shear head bolt Tighten to shear **
And for us Amuhrikans, we need to remember that the capacities are given in Imperial measure, which are different than our local pints/quarts/gallons. I find it simpler for myself to just convert the given metric capacity units to US measure.
Current keeper of “Project PFJ”.
I was “SCMike” in a previous life on this Forum.
Not only that, but neither of them are classed under "Blue"!
Incidentally, Shadow blue is a trim colour.
Carledo wrote: ↑Sun Feb 13, 2022 2:21 am
Maybe they just ran out of space in the "Blue" row in the table and shoved it in somewhere else?
