I have just bought a new rotor for my 1850 Dolomite. The original rotor is bakelite or something similar, quite rigid. The new one is plastic and flexes a little if squeezed (Intermotor brand part number 47810, which is said to be the same as GRA111).
The bottom of the rotor has a couple of keyed projections to ensure it is installed the right way, one square and one circular. On the old cap, they are 44mm apart. On the new one they are 45mm apart, and slightly larger. The new one does not fit easily. It does fit if I force it but I am concerned that it may distort the rotor and affect the clearances.
Fortunately, the keyed pins are at right angles to the axis of the contact on top, so maybe not?
Thoughts?
Distributor rotor different size?
1975 Dolomite 1850 manual (no overdrive), French Blue
Owned since 1976.
Owned since 1976.
Re: Distributor rotor different size?
Cheap crap part.
Try and source something better, an original one off eBay maybe.
Same rotor fits Vauxhall Viva 1600 1800 2000 and 2300, Victor FD 1600 and 2000, Victor FE 1800 and 2300, Bedford CF 1800 and 2300, Viva GT, Firenza and Magnum. Might widen your search.
I thought it might be. Would you happen to know the part number?
Now I am wondering if the distributor cap is any good. It looks a fairly faithful copy of the original, except that the contacts are a silver colour rather than brass on the original.
Owned since 1976.
Owned since 1976.
- yorkshire_spam
If it's the same Delco type dizzy I have on my 1850 then the part number on this Lucas one might help track one down?
Where did you get the shonky one from? Wonder if these are any good? https://www.holden.co.uk/p/rotor_arm_tr ... xhall_saab
Rotor is Delco part DB411 or CR6003, Motaquip VRA107yorkshire_spam wrote: ↑Mon Jan 31, 2022 2:16 pm If it's the same Delco type dizzy I have on my 1850 then the part number on this Lucas one might help track one down?
Dizzy cap is part Delco DB302 and there is a NOS one on Ebay now, https://www.ebay.co.uk/itm/275131771241
Also Intermotor 44830 or Motaquip VDC128
Russ Cooper
Dursley
UK
Dursley
UK
Just to wind this up, my parts supplier had got a new rotor in to replace the one they sold me. It turned out this was a Delco part so now I have that in the car and it fits perfectly.
Owned since 1976.
Owned since 1976.
I'm pleased I read this, I found a genuine NOS AC Delco rotor arm on ebay, a bit expensive but i bought it for stock, in case I ever need one.
Malcolm
Malcolm
