1500TC Springs and Shocks
On holiday at moment so no access to manual; Rimmers have 12% off GAZ springs and shock absorbers (RT1273 kit) however my car is a an 1974 Triumph 1500TC, please could someone advise if the standard dolomite springs and shocks in the GAZ kit will fit? Thanks
Re: 1500TC Springs and Shocks
Hi Mark
For fitting coil overs to my 1975 1500TC I needed to replace the front spring upper mounts with below.
Front Spring Upper Mounting Plate - Sprint/1850 - Part number 157333
https://rimmerbros.com/Item--i-157333
Regards
Barry
Regards
Barry
Aberdeen
…but the picture shown on that Rimmer Bros web page is a top mount for 1300/1500, not Sprint/1850, so check exactly what they have before ordering!
The Sprint/1850 spring top mount has an additional circular flat plate spot welded to the underside to accommodate the bigger diameter spring.
Hixvivalve wrote: ↑Thu Jul 28, 2022 8:32 am …but the picture shown on that Rimmer Bros web page is a top mount for 1300/1500, not Sprint/1850, so check exactly what they have before ordering!
Yeah, it was the issue with the AVO shocks I had were the spring not fitting, It was Jigsaw that sold me them the the top mounts!
Regards
Barry
Aberdeen
